How to Rid Key-in Reminder Beep ?
I've never looked at the side of the doors on the TL, but if they are anything like Accord doors, there is a small lever that pushes in (or out) when the door is closed. If you place something there to keep the level in (or out) then the beeping will stop.
Another way is to remove the key. Actually, you can turn the key so that you have power without the beep going off. Acc I or II mode??
Before you start a heated diuscussion, huckleberry, I should explain that you didn't ask this question about a TL; and since this is a model specific type of question you should post this in the TSX forum, since you have a TSX, or the Car Talk Forum and specify the model.
Since we can't move threads into other forums, please repost there if you wish to continue this discussion.
