How to remove/realign the door
I need to realign my drivers door. I have been looking through the garage but cant find any information on how to align the doors or remove the door. Does any one have any information on how to do this. It would be greatly appreciated.
Thank you
Thank you
You shouldn't have to remove a door just for realignment. However, you can if you want to but check to see if the door wire harness unplugs at the front door post.
To remove the door there are four bolts you can take off at the door hinges on the door side.
There's no difference in how a door is attached, removed, and aligned from different generations. Only the shape of the door and the hardware is different.
For reference click on the link below...
https://acurazine.com/forums/problem...cement-929421/
neil0311
01-20-2016 09:27 PM
Acuraneewb
01-12-2016 01:43 AM
