How Much is A1 Service.
Old Jan 30, 2007 | 09:15 AM
TL310's Avatar
06 TL
How much you guys pay for your first service on the car.
Old Jan 30, 2007 | 09:23 AM
kappa821's Avatar
70 or 90 dollars somewhere in that range......i think it oil change filter rotate and balance tires.....how many miles did you put on the car before that came up
Old Jan 30, 2007 | 09:33 AM
berite100's Avatar
70? 90? for an oil change? geez...i been quoted 39.99 and i am going in for my A1 and i have 5000 miles.
Old Jan 30, 2007 | 09:35 AM
kappa821's Avatar
70 or 90 dollars (i cant remeber) that includes oil change rotate tire and balnace........5000 miles thats pretty quick i got my first one at 7 something
Old Jan 30, 2007 | 09:42 AM
paz840's Avatar
i got my A1 done for $45....oil, filter, tire rotation, wash, etc.
Old Jan 30, 2007 | 09:54 AM
TL310's Avatar
06 TL
It came up this morning, I only drove 5 miles proably get it done friday.
I have some rattles that need to be fix, is it cheaper if they dont rotate ur tires?
I have 5400 miles
Old Jan 30, 2007 | 04:24 PM
TL310's Avatar
06 TL
WTF How you do that I called 2 dealers right now and they want to charge me 130.00 wtf.
I have to go in there and tell them what I want.
Old Jan 30, 2007 | 04:28 PM
TL310's Avatar
06 TL
hahaah I called those fuckers back and regulated,
they are trying to get me for rotating, check pressure, check brakes check tubes
just b.s. really so now its 34.99 lol !
Old Jan 30, 2007 | 05:14 PM
Thorin78's Avatar
Previous Owner
I remember my A1 service being like $36.
Old Jan 30, 2007 | 05:28 PM
Eoanou's Avatar
'10 Hyundai Genesis Coupe
Is the A1 service automatically done at your first oil change?
If so, then mine was free of charge.
Old Jan 30, 2007 | 05:45 PM
TL310's Avatar
06 TL
Yes it is oh wow.
Old Jan 30, 2007 | 05:47 PM
SteveP66's Avatar
Kaa - Ching !!!
From: Rhode Island.....Self-Proclaimed Chromed Cousin of Brettallica
Yeah mine is free too - once it rolls around - only 3800 miles for me here
Old Jan 30, 2007 | 06:45 PM
Hooksta's Avatar
Hooksta
I'm new to the TL family so I have a couple of questions.
Is there some reason why I need to take my TL to the Acura dealership for an oil change? And if I don't, how do I reset that "Oil Life" setting? I remember an old Accord I had, you just used your key (or something of simliar size) to reset the green light. It would turn yellow and then red when service was needed.
Old Jan 30, 2007 | 06:59 PM
jptl04's Avatar
Bone stock tl-s
ha! ha! i told you man! sometimes you gotta "check" those guys at the dealer, or they'll nickle and dime you for every cent!
Old Jan 30, 2007 | 07:00 PM
RedlineGraphics26's Avatar
& U Already Know
Whoa, I paided like $130 for my A1 service... damm i just got raped.
Old Jan 30, 2007 | 09:00 PM
sunny201's Avatar
A J35A8 EG civic is in
Yea I went for my first service and got Mobil1 Synthetic, tires rotated, and a car wash for $50. I went to the dealer and they were asking $119, lol so i just went to my friend and got it done.
Old Jan 31, 2007 | 09:06 AM
TL310's Avatar
06 TL
yea man I had to get loud with those fools.
Old Jan 31, 2007 | 09:40 AM
berite100's Avatar
we should keep a list of those acura shops that raped its customers.
hope that will keep those guys honest. do they expect return customers? and how does Acura feel about its authorized shops from raping its customers. or do they stand behind customers beware bs?
Old Jan 31, 2007 | 11:51 AM
paz840's Avatar
You don't have to take it to the dealership...definitely do it yourself if you know how.
The only reason I didn't was because I don't have a garage and it was 20 degrees outside.
Here are Ron A's instructions on resetting the MID display
Originally Posted by Ron A
Here’s the full procedure to reset the MID display, and also info at the bottom about other service reminders when you manually reset the MID yourself.
(The procedure on page 196 (of the 2004 owner's manual, and probably for later models also but if anyone has a later model with the correct procedure please let me know) of the manual is incorrect. In paragraph 3a of the manual, the requirement to hold the button for 10 seconds the second time it is pressed is omitted. If this is not done, the display will not reset.)
1. Turn the ignition switch to ON
2. Select Trip A or Trip B (You can use either one, so if you are using one to record data for something, use the other one to reset the Oil Life Indicator).
3. Press the < or > button repeatedly until the oil life is displayed.
4. Press and hold the Select/Reset button for 10 seconds. The Multi-Information Display will ask for a confirmation.
      This will explain what happens to the other services items when you reset the MID before the service due message appears.
      From the service manual, page 3-6: (NOTE: This information is not in the owners manual.
      NOTE: If you are resetting the display when the oil life is more than 15%, the maintenance message "Service Due Soon" will be displayed. Make sure the maintenance items requiring service have been performed before resetting the display.
      So this means if you change your oil before the 15% Service Due Soon is displayed, and you go to reset the display, if there are other items to be serviced, they will show up on the display, and if you clear the display the MID will take this to mean that you performed the required service.
      To clear the display:
      After you get that service screen hold the reset/select for another 10seconds.
      It will then ask you a question. I don't remember exactly, bus something about do you want to reset.
      Press the reset/select button and the MID will be reset
      The above information may not be exact because I did it a while back and forget exactly what I did, but the next time I will write it down and update this if necessary.
      The statement from the service manual is a little vague, and I think they meant to say that if other items require service, the message "Service Due Soon" will be displayed, since if there is nothing else requiring service there would be no need for the message.
      Old Jan 31, 2007 | 08:21 PM
      cristphoto's Avatar
      My first service was free. I also received $100 on an Acura card that was in my owners manual. Tischer Acura in Laurel, Maryland. I've had good luck with them.
      hrothgar02
      Oct 21, 2015 05:49 PM
      TL14
      Sep 24, 2015 04:37 PM
