How many spark plugs do we have?
I know, stupid question, but how many spark plugs do we have in our TLs? 6?
Originally Posted by cust0mx
(Post 12311907)
that would be 6 :thumbsup: |
Every car has one spark plug for each cylinder. TL has 6 cylinders, therefore 6 sparkplugs.
And yes it was a stupid question :) |
:doh:
Originally Posted by Aman
(Post 12311928)
TL has 6. |
Originally Posted by LostSol_FoundTL
(Post 12311990)
Not true, new Ford 6.2 has 2 per cylinder.
TL has 6. 1 per cylinder for like 99% of the cars out there. Some oddballs like some Ford 2.3s and certain Toyotas. More of an emissions thing than anything else. |
^haha sorry I just had to
6 ??? i thought we had 14 upfront and 3 in the back....under the engine....
Don't forget the Nissan Hardbody pickups trucks from 1987 - 1990 those had 2 plugs per cyl which in turn was 8 plugs on a 4 cyl truck
Originally Posted by I hate cars
(Post 12312145)
LOL. I knew someone was going to say it eventually.
What's the advantage of multiple plugs per cylinder?
From Edmunds Inside Line's Dyno of the F-150 Raptor 6.2L:
"a measure made necessary by the large-diameters cylinder bores -- large combustion chambers burn their contents more slowly than compact chambers" |
Current Dodge Hemi-2 plugs per cyl. One fires on compression, the other on exhaust to help emissions.
^^^ Interesting.. I've never heard of this.
Originally Posted by swoosh
(Post 12312331)
I have 12. But then again, I've got 2 TL's. :tongue: |
(Post 12311928)
6.
Originally Posted by Turbonut
(Post 12312640)
Even my old GN uses the waste spark method of firing each plug on power and on exhaust. It fires backwards on the exhaust stroke (outer to center). In my case it wasn't for emissions, just what happens with one coil for two cylinders. |
yes so did my old 2004 dodge ram hemi 2 per cylinder :thumbsup:
almost all but not all |
I have 28 in my garage, 12 in the 760, 6 in the TL, 6 in the MDX and 4 in the accord :tomato: Good luck with whatever you do decide to do! FYI if you are changing the plugs, USE ONLY THE NGK Iridiums! Don't go with denso!
(Post 12312747)
Are you sure they have two plugs or do you mean the waste spark method with a single plug?
Even my old GN uses the waste spark method of firing each plug on power and on exhaust. It fires backwards on the exhaust stroke (outer to center). In my case it wasn't for emissions, just what happens with one coil for two cylinders. The Mazda rotary has 2 plugs per housing that fire 20 degrees apart (leading and trailing) to better burn the mixture, but the leading plug also has a wasted spark as both leading plugs fire at the same time in housing 1 & 2 while only the trailing plugs fire when needed on compression. At least one can't mix up the leading plug wires. |
The Mercedes M112 & M113 engines also use 2 Plugs / Cylinder, again mostly for emissions.
Originally Posted by Bearcat94
(Post 12312713)
I have 12.
You guys suck.
