How long between 3x3 Transmission Intervals?
Just picked up 9qts of Redline Racing and was wondering how long should I wait to do a 1x1, should I do my first drain and fill then wait a week (prefer not to because don't feel like jacking up and taking all the supplies out again) or drain, fill, ride around for 5-10 minutes then do another 1x1? Just don't know if me driving around for 5-10 min will give it enough time for the fluid from the torque converter to flow all the way out? Thanks!
you can do the 3x3 on the same day. drive around for like 10-15 mins making sure you went to all the gears and when you get home go into reverse a few times. let it cool a little bit then drain and fill
under renovations....
I did mine all the same day. And being that I have a type s I drove it in ss mode to make sure I got all the gears. Luckily for me I live right next to the parkway so I was able to open it up quickly. A little more then 3 qts might come out too that's what happened to me when I did mine. Wasn't much of a big difference in amounts I just made sure itwas completely clean red fluid.
mada51589
05-03-2022 08:54 PM
Mike Bertram
09-10-2015 09:27 AM
darksky
09-05-2015 03:11 AM
3x3, acura, acurazine, atf, drain, driving, fill, interval, long, rdx, siteacuraclcom, tl, transmisison, transmission, tsx
