How to get rid of rust for good, or at least 3 years
Posting here because this forums is a lot more lively than the MDX and I own both MDX and TL.
The MDX is a 2005, white and it started rusting 2 years ago below the gas cap, around the wheel arches and around the doors. We had it repainted by a bodyshop for 2k$ but the rust is already back.
This in in Quebec with winter, salt and all that body rusting situation.
Is there a way to fix this for another 3 years? Should I just abandon and learn t live with rust?
modoko (06-08-2014)
Resident Dingo
What's the name of that company that sprays on the protective stuff?
Not sure if they have it in Canada, but I know a lot of folks around the DC area use them.
AZ Community Team
Received 7,771 Likes
Sounds like a defect of some kind. Why is it rusting in the first place? And why is showing through the paint?
Pics?
Also, FWIW, threads go in the section the question pertains to, not based on the what car(s) you own. Non-model specific or non-Acura = Car Talk; Model specific = that model sub-forum.
Pics?
I've got a little rust on my inner fender lips from rolling them before the winter. I'm going to be putting POR-15 on them. You can put that or Rust Bullet on it and then paint over that. Either product should seal off the rust.
I have rust on my car too.
How it formed, IDK.
I'll post a thread about my rust soon, but I have it on the hood, rear passenger quarter panel on top of the wheelwell, and some rust starting around my tail lights.
AZ Community Team
In areas that are exposed, like the under-carriage, it's understandable and typical. In un-exposed areas, like painted, undamaged panels, it seems unusual to me.
AZ Community Team
But it's BAD rust.
Very unexpected, as there was no VISIBLE rust when I bought the car.
Rust usually starts from the inside and comes out through the body panels, unless paint is missing then the rust can be considered surface rust. Normally with the galvanized steel that is used, rust is at a minimum unless body work was performed and the panels weren't sealed properly and water was left to remain within the panels. The daughter's Maxima, never in an accident started rusting in the lower qtr just behind the rear door, only on one side, passenger, and seems "normal" with the Maxima as many have the problem. I cut out the rust, both inside panel, exterior panel along with the wheel well arch and all toll,, about 2' just to get to "clean" material. Pieced in new metal, sprayed inside and out, sealed the inside area, then sprayed the primer, base and clear on the outside.
Only way to stop the rust penetration is to cut it out, at least in my opinion. POR 15 is great, but getting to the entire rusted area is sometimes a problem in that what is not coated will just continue to rust.
Cars up North certainly take a beating from the hardh conditions. I had a 2001 Grand Cherokee that came from Minnesota, it was a disater as the engine block was flaking from rust, oil pan rusted through, brake lines and A/T cooling lines heavy rust, so changed the oil pan then got rid of the SUV.
Warranty, looks like 5 years Canada:
The outer body of an Acura is under warranty against rust. The rust-through warranty is good for five years and is not limited by the number of miles. Surface rust 5 years 80,000 km
OSPHO! It stops the rust in it's tracks. I paint for a living and use it religiously(spelling). You can either brush it on or use a spray bottle. Let it sit 24 hours then lightly sand smooth. You don't need to do the sanding part unless you are planning on painting soon. if not, just brush or spray it on and leave it. Good Luck.
Look up Ospho my friend. Obviously you would want to get rid of the water first that is causing the rust to form then use the ospho. Again, I use it all the time and never had an issue. Also, it is not a rust preventative, it stops the rust in it's tracks and turns it into iron phosphate.
I've used it on driveshafts, suspension components, and other out of sight body parts as a primer before painting, but the parts have been as new before application.
As usual, just my
I've used POR-15 over the years for a variety of projects, and the Ospho is similar to any of the other rust preventative products, but once again, if one has a small hole in the wheel or qtr, it's not going to help as how can one be certain all the rust areas inside are covered. Use as an example the qrts and wheel wells that have a filler and rust has begun between the 2 layers under the filler, no Ospho or any other liquid is going to do the job. Even for surface rust, the metal needs to be prepped and rust areas ground down smooth before applying paint, so the rust area is gone. Now if one wants to spray the solution over the rust and simply paint, that's a different story, and a completely different final appearance, far from factory.
As usual, just my
As usual, just my
Interesting I also have a 2005 MDX 66k miles , garaged and have rust back undercarrige, pipes & lifts Looks surface but usually that turns worse. I spoke to Acura last summer Augsut 2011 and the of course said no big deal its normal.... Not really _ i had a Accord - drove it for 156K also garaged and not a spot of rust - whats the deal with MDX's ? Is there a way to stop the rust ?
OP rust will come back almost every year unless you spend alot of $$ to get the whole section cut off and rewell other than that you will have to live with rust, I spray wash my car almost every day after driving home to make sure that all the salt being blast off the body especially between gaps such as bumper meet fender/quarter panel/headlight/gas door and under wheel arch, I have a 00 Accord with 140k miles and that is my daily driver so far I have zero rust any where on the car.
nanos
11-12-2015 08:41 PM
Oakes
Wash & Wax
10-12-2015 11:17 AM
IIDXholic
10-08-2015 07:53 AM
sockr1
10-01-2015 01:31 AM
