How come auto only comes in D and Manual?
One thng I noticed during test drive is that the automatic only has two options: Normal Automatic and Manual Shift. Im not sure what the G35, audi's, or others have but I know the 3 series auto has 3 modes: Automatic, Sport Mode Automatic, and Manual shift. Does the TL have the 3 modes and I just didnt know how to set it during test drive or are there only 2 modes?
If there are only 2 maybe that would be a good feedback to give Acura. Having a sport mode should be a relatively trivial thing to add to car given it is just a different shift point (performance vs fuel economy) -
I don't have a Ferrari in
I dont know what you are talking about. The automatic 3 series doesnt have "manual" shift because it doesnt have a clutch. If you are refering to StepTronic, then its like a manual but not truely because the ratios are still different. In any case, the 3 series still has only 2 modes.
Mocoso is actually talking about different programs for the automatic shifting. I forgot which car I drove that had that feature. It was definitely a Mercedes or a BMW. There was a button to allow the driver to select how he wanted the automatic to shift. Sport mode would delay the shift of gears till after a higher RPM while the winter mode will allow for shifting at a lower RPM to decrease torque on the wheels.
I think it's was not in Acura's interest to persue this in R&D because it wasn't a major benefit. The current set-up for the TL is quite well already with a fairly aggressive shift based on throttle position. When slowing down, the transmission is very responsive in downshifting to the correct gear to match the vehicle's speed. The engine is tweaked for ULE. If tire slipping was an issue in snowy conditions, VSA would decrease power to increase traction. The TL's an all-around well thought out package that covers most conditions with a less agressive sticker price.
Cesspool of Knowledge
Actually, I find the Acura's throttle-based shift scheduling to be a better implementation. It's fuel efficient during most of my normal driving, but it kicks in aggressively when it determines the need-for-speed.
The TL's shift scheduling has surprised me on occasion, because I'll realize immediately after I throttled up (but not floored it) and changed the normal scheduling that I really needed the extra boost at that time. It's almost like the car is telepathic ...
Not a Blowhole
BMW's have the S-program. You engage it by moving the lever to the manual position without shifting. It raises shift-points and makes kick-down more responsive. It really changes the character of the transmission.
The whole idea of adaptive shifting is for the transmission to detect when the driver's pushing it hard, and to alter the shift program automatically. Does the TL have this? I haven't seen it documented.
Anyone notice the BMW Steptronic does its manual shifting "backwards?" Push forward to downshift, backwards to upshift -- like steering wheel paddles.
BTW, the TL also has a "Low" mode, where the transmission maintains the lowest possible gear. An interesting ride, to be sure, but I'm not sure if it's realy "good" for anything.
I didnt realiza the TL was trying to do the adaptive transmission throught the use of the "fly by wire" throttle... I guess if it is automatically detecting the type of driving by how the throttle is being used then there is no need for the adittional "Sport" mode.
And yes I noticed the BMW is "backwards" but it did NOT use to be this way.... my 01 330 has it configured as forward for up and backwards for down... dont know what year they changed it but my brothers 04 525 has it the way you described... I would love to know why they changed it...but thats for the BMW forum...
Actually, I was posing a question. I don't really know if the TL's 5AT is adaptive or not. Does anyone know?
Taken from page 22 of the 04TL sales brochure:
Drive-by-Wire Trottle System
Instead of using a mechanical means to transmit the accelerator pedal's action to the induction system's throttle, the new TL uses a sophisticated electronic throttle control system. Various sensors in the engine and chassis supply data to the system's computer, enabling it to apply appropriate input to the throttle body. So when smooth driving is important -- such as in congested traffic or on slippery pavement -- the throttle response is more gradual. When instant acceleration is desired, the throttle will respond with more immediacy. Control is enhanced and driver fatique is lessened. And this system is integrated with VSA to provide a more stable and refined driving experience.
I've also noticed by watching the tach while experimenting with my driving style, that the shift points can vary significantly depending on how I'm applying the accelerator. It looks like there may be multiple shift schedules at play here, all integrated into a seamless system.
Way to go, Acura!
About the only time I regularly use the Sport Shift mode is when I'm merging into congested highway traffic, and may want a little extra "Ooomf". However, the TL does the same job perfectly in full automatic mode - it's just a psychological thingy that makes me feel like I can do the job better!
Originally Posted by Road Rage
I agree with you - it is a simpler yet more sophisticated solution. The only question i have is can the TL be started in 2nd gear as in some automatics?
-r
-r
Black
I thought only Mazda had the manumatic the "proper" way (forward for down, backward for up). Racing cars with sequential shift do it this way to help you shift with your momentum (and being there's so little space in the cars, there's not much room otherwise).
On the adaptive question: BMW do have adaptive shift points when in full auto - I suspect Acura does as well.. it does monitor the driving habits of the driver and adjust the shiftpoints accordingly with an effort to conserver fuel.. the "sport" mode in the full auto in BMW is tuned to get performance (Im not sure if it adapts to driver) - and while yes you could use the "manual" mode to get the performance Ive found that due to the lag from pushing the handle to the actual shift (one limitation with autosticks) the "sport" mode usually gets me there faster (Yes Im no speed racer and in my old age )
Moderator Alumnus
Originally Posted by rets
I like this way, too... for me, it makes sense to pull for "upshift"...
-r
Originally Posted by acura_driver
I don't care much which way they do it. But I wish the manufacturers would all do it the same way. It was a bit challenge a year ago when I was test driving different cars!
-r
-r
yes our TL has the learning "fuzzy" transmission. It averages driver's habits over a 7 day period to determine shift times. If Grandma drives it for a week, then you get back in and floor it or try to highway-pass, it will be hesitant until it learns that you're back in control for a day or two.
Team Anthracite Member
Acura should have left it like it was in the '02 where I could choose OverDrive when I wanted it. I don't like how we are always in 5th. I know in SS mode I can do that, but then I gotta be shifting all the time, and then I could have bought the 6mt if I wanted to be shifting. I got used to it, but that was my only real gripe. Car still ROCKS.
I agree on the overdrive suggestion too, but for opposite reasons
I wish overdrive would stay engaged, when i'm accelerating from 60 to 65 mph. I hate how the damn automatic drops out of overdrive, or worse drops out of overdrive and shifts down to 4th, when I'm just lazily trying to get a few more mph out of the car.
If I use SS to increase speed, it'll still drop out of overdrive during these small increases in speed.
To the people that want a quiet highway ride, we can't ever adjust our speed up, like when a highway goes from 55 to 65 speed limits. The car will always roar to life.
I guess in the end it's my fault for not getting the manual. Marriages have their good and bad points
'06 750Li Sapphire/Creme
lanechanger
10-13-2015 10:56 AM
