how to calculate LED resistors
I brought the switchback led bulbs, but i am not what is the correct size of resistor i need. i saw couple threads that people use 2 6ohms 50w per led and others use 4ohm 100w.
Does anyone know the math to calculate the correct resistor.
Q's
1. does all power resistor heat up like a bulb?
2. i have some 10ohm 50w resistor will this work.
thank you all
Q's
thank you all
all resistors heat up it means they are working.... BUT they are not supposed to heat up the way some people describe with turn signals. so obviously they arent using the right ones but they'll work.... i wont do them until i get back to my shop and probe the lines to see what resistance values the lines have
Mike's Silver Bullet
I don't know about the specifics of LEDs, but this sounds like simple circuits stuff.
You need to know what voltage the LEDs are supposed to be supplied with, and how many amps they draw at that voltage.
Then use ohms=volts/amps to determine the ohm value of the resistor you need to drop the 'extra' voltage.
Once you know how many ohms the resistor you need is and how may amps will be flowing through it, use watts = amps^2 * ohms to determine how many watts will be dissipated. Buy a resistor rated at 2-3x the number watts you will dissipate.
Example (I've got no clue if these values are even close): led is 5 volt and draws 1 amp.
12 - 5 = 7 volts to drop.
1 amp flows through the resistor, since you hook it in series.
7 volts / 1 amp = 7 ohms.
1 amp^2 * 7 ohms = 7 watts.
So in this example you'd need a 7 ohm 25 watt resistor.
I hope this helps.
I hope this helps.
Q's
thank you all
Q's
thank you all
It is use across the LED's 2 wires (One Common and the Flasher Led) so that the current consumption is about the equivalent of a regular bulb on the flasher circuit.
see the following thread for more information:
https://acurazine.com/forums/showthr...hlight=flaSHER
spoiler900
10-10-2015 06:48 PM
