Highway Robbery!
AVB for President!
Highway Robbery!
So I called my local dealership to get quotes on various services that I will be needing soon:
1. Timing Belt Service - $1,350. Includes timing belt, drive belt, water pump, and tensioner. Does NOT include adjuster or idler pulley. If I provide my own parts, its $828.
2. Spark Plug Service - $250. If I provide my own plugs, its $145.
3. Valve Adjustment - $550
4. Thermostat Replacement - $255
Put everything together, it's $2400 and this doesn't even include the adjuster or idler pulley.
AVB for President!
Another dealership quoted the same ($2400), but includes the adjuster, pulley, and even the AC belt. But no thermostat. However, he was willing to charge $40 for the part and zero out the labor for the thermo. So all in, $2440. I can save another $100 by buying the plugs myself, so $2340. He's willing to give me another $150 or so off, so $2200 is probably the lowest I can get for all services/parts included.
Buy your own parts from a vendor and go to an independent mechanic. I just bought motor mounts from a vendor here, all 3, went to my indy and had him install them, resurface the rotors, oil change, and tire balancing and alignment, all for $300 + parts. He did my spark plugs (I provided) for $130.
You definitely have to call around; this includes Honda dealerships local to you. Needless to say, the quoted price on belts, pump and tensioner is excessive. Should be sub $1000 incl labor.
Just out of curiosity, did you get the display telling you the code/maintenance that needs to be performed, or just kept track of your mileage?
I'm questioning whether or not to do the timing belt service done on my vehicle (65k mileage) but at the same time, whether or not to wait till' I get some kind of message from the display (although most of the maintenance was taken care of when I first bought the car at 44k)
Thanks.
Thanks.
AVB for President!
My MID has yet to display the "4" maintenance code. However, my car has 103K miles, so I'm pretty much in need of the TB service.
Thanks.
Thanks.
B A N N E D
1. not quite sure what you mean by adjustor (i would assume tensioner, but you have included that though), but yes indeed make sure to also do the idler pulley also, you really only want to go in there once till the next t/belt job is required at roughly 210k miles), also don't forget seals either, don't want oil leaks eventually
2 & 3. valve adjust takes a little bit to do, cause the intake manifold has to come off and such, and since the ignition coils already have to come off for the valve covers, and the valve adjust, changing plugs out, should only add like 0.5-1 hour worth of labor, since you are already basically in there
4. coolant loss, overlaps with the t/belt service, since the system will already be drained, and i would assume they are charging about an hour to do it (a little less, since the cooling system drain and fill part, ishould be part of the t/belt)
and i am figuring there shop rate is $140 an hour, i know here in Colorado, most independent shop rates are somewhere around $100 or less, so that $40 an hour buys you alot lol (you do indeed pay for those fancy waiting areas, and nice loaner cars)
but as others have said INDEPENDENTS FTW (except for warranty work though lol)
AVB for President!
Yeah, labor here in the bay area Acura dealerships is around $140-$150/hr. I just don't have an independent shop that I know that I can trust to do this job. I'm definitely all ears if someone knows of any mech that they would trust to do this.
They don't call them 'stealerships' for nothing.
You have to get in good with the parts manager. I did that with my Subaru and ended up getting any part I wanted at dealer cost or sometimes 10% under dealer cost.
The markup of parts is ridiculous and how they make most of their money now.
B A N N E D
also another way to help find a good place, is call up the local tow companies, they normally have a pretty good idea of who does quality work
along with the tool representatives/dealers also for Snap-ON, MAC, Matco, Cornwell, etc.
and i get Acura (my car), Subaru (wife's), Hyundai (if i wanted lol), AND from there performance division (sells mostly subaru parts in stock, but can order for my car though) all at wholesale
I don't know how far you want to drive but my trusted "Japanese car" mechanic in Fremont did my timing belt, water pump, all drive belts and hydraulic tensioner; along with the spark plugs, an oil/filter change and replaced a front engine mount – all for $1211. The parts were $595.
I have been taking my Acuras and Lexus to Kenny for over 10 years now and have always been very satisfied with his work. Google Kenny’s Auto Repair (5 stars).
Why me??
at the Honda dealer i work at we charge $830 for the timing belt job. that includes timing belt, water pump, crank seals, drivebelts and coolant. we will replace tensioners if needed no addtional labor, only parts. thermostat $90, spark plugs $215.
valve adjustment $330 ....$550 is insane.
B A N N E D
was just wondering, and doable checking
I have a friend that is mechanic in Acura dealer in Gainsville ,FL and he told he can get all this job done in his house for $250. I already have all the parts but I'm not sure because I would like to have a receipt from all the work done just to have records, but just $250 is very tempting!!!
Why me??
flat rate time does not = actual time spent.
say you have 2 brake jobs that pays 2.0hrs a piece flat rate, 1 master tech and 1 entry level tech. they do the same job and get paid the same but it may only take that master tech 1-1.5hrs and that entry level tech 2.5hrs. should you be charged more because a slower tech worked on the vehicle? should the master tech make less because he is quicker?
if a shop pays there techs flat rate then you will be charged for the job by the menu pricing set up at that shop not how long it takes.
rockyboy
01-25-2016 06:00 PM
guyvelella
09-30-2015 11:02 PM
