HID replace with LED 2007 TL Type-S
#42
Just ordered some 3000k LED bulbs with resistors for the DRLs and fogs.
Will have them today and installed after work. I have replaced the DRLs already so that should be easy. And tips for the fog lights? I'm guessing I pull back the fender liner in the wheel well?
#44
lift front end of car, turn wheel other way and access through fender line. Or if you're not lazy, just drop the bumper
#45
ThatBlackTL (08-14-2019)
#47
So I swapped out my stock DRLs for some 3000k LEDs () with resistor, don't work. I put my stock bulbs back in, works just fine. Not sure if it's bulb or resistor.
Anyone have luck with 3000k DRL bulbs that they can recommend?
#49
So I bought the car from my buddy who already had LED bulbs in the DRL, but they weren't working. I removed those and put stock bulbs in, they work fine.
Recently bought some 3000k LED bulbs for the DRL with resistor (
Seems like most of the guys here on the forums run resistors with grounding wires and to the battery terminal. @thoiboi mentioned these might work: https://www.vleds.com/shop-applicati...ra/r2-drl.html so I might give those a try.
https://www.amazon.com/Win-Power-Canceller-Decoder-Fix-2007-Current/dp/B077XHFNG6/ref=sr_1_11?crid=2CZ2PAGWBUIX3&keywords=9005+drl+resistor&qid=1565973788&s=gateway&sprefix=9005+drl+resi%2Caps%2C199&sr=8-11
) but they don't seem to work.I think maybe it's the type of resistor I bought?Seems like most of the guys here on the forums run resistors with grounding wires and to the battery terminal. @thoiboi mentioned these might work: https://www.vleds.com/shop-applicati...ra/r2-drl.html so I might give those a try.
#50
Stock DRL are run in series to reduce the power output. To run LED DRLs you either need to modify car harness (like I did) or buy/make aftermarket harness with separate relay and power source.
I have a feeling that I posted the link to my thread too many times, but here it is again:
https://acurazine.com/forums/third-g...nstall-960677/
#51
DRLs run at 6V. Not all LEDs are rated to run at that voltage and a resistor is not going to help that. That's why I was perplexed that yours worked. So that's means your a set works at that range.
The harness would provide full 12V power that LEDs need.
