HID fog lights
HID fog lights
so ive searched the forums and found nothing.
I recently purchased a HID kit for my fog lights. When i installed them the lights flicker for a second or two then turn off. I then try to turn the fog lights on by switching the fog light switch on and off and still it just flickers and turns of. Since i dont know whats going on with these things i just put the stock oem bulbs back in and it still works.
Maybe i need resistors? relay harness? iunno whats going on
thanks
thanks
The following 2 users liked this post by ez12a:
paperboy42190 (11-05-2013),
thoiboi (11-05-2013)
This is what happens when one buys junk HID plug and play kits.
My first thought would have been that they need a harness, but paperboy says thats not it. So then the only thing it could be is bad bulbs or ballasts.
Balling in the...
As MVP2765 said its best to use the HID harness for HID Fogs. You have to remember your HID Fogs will be using up more power than the regular halogen bulbs and this Harness lets your HID Frogs get direct power from your battery insuring they get the correct amount. This harness also comes with a relay and a fuse to give you more added protection. If you guys are having issues I would do this after check all Your fuse and ground leads
InFaMouSLink
10-27-2015 06:51 PM
sockr1
10-01-2015 01:31 AM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
