HID BULB 10000k (Purple Tint)
Old 08-26-2004, 10:50 AM
  #41
O.G.
BlackShadow's Avatar
Originally Posted by 1SICKLEX
Ya'll have to watch out for high-output bulbs, they will BURN your harness. B/C the harness is built for maybe a 55W light, not a 80W one.
Actually, even the 10K bulb is only 35 watt.
BlackShadow is offline
Old 08-26-2004, 10:59 AM
  #42
O.G.
First of all, 10K is not purple. How do I know, cause I have them. Here is a comparison pic of 6000K vs. 10000K on a 99 TL:
6000K:
10000K:
6000K:
10000K:
Old 08-26-2004, 11:13 AM
  #43
BdasAcuraTL's Avatar
aah, finally some pics.... thanx BlackShadow.
BdasAcuraTL is offline
Old 08-26-2004, 10:01 PM
  #44
9.5+10.5 22m=Hella Flush
ed99's Avatar
6000K:
10000K:
6000K:
10000K:
Nice Pics dude and just want to know which one you prefer. I mean it looks like the 10000k looks alot bluier than the 6000k bulb. Since you have both, which one can you see better with and which one do you use for your daily driving???
ed99 is offline
Old 08-27-2004, 01:44 AM
  #45
O.G.
Of course you can see better with the 6000K cause the higher you go, the less light you see on the road. Just like you can see better with the stock 4300K than the 6000K.
IMO, I like the 10000K better cause I wanted that bluish hue to it. And I use it as my daily driving.
Old 09-13-2004, 05:52 PM
  #46
flnsx's Avatar
Does anyone actually have the 10k bulbs installed on a 2004 TL?
ANYONE?
Report damn you!!
flnsx is offline
Old 09-14-2004, 01:40 AM
  #47
ed99's Avatar
ANYONE?
Report damn you!!
I am just as curious?????
ed99 is offline
Old 09-14-2004, 04:36 AM
  #48
Rkat's Avatar
I thought the stock headlights sucked in my Acura,Not very good distance,Guess I'm not used to hid's.
Rkat is offline
Old 09-28-2004, 11:43 PM
  #49
ed99's Avatar
OUr TL lights are aiming lower than normal and that is why you are not getting any distance!!!
ed99 is offline
Old 09-28-2004, 11:57 PM
  #50
Rkat's Avatar
Well I guess that explains that..but they still suck..
Rkat is offline
Old 09-29-2004, 12:53 AM
  #51
ed99's Avatar
The only way is to adjust your headlights a bit should do the trick!!!! Just make sure you don't blind the other side of the road and you will be fine.
ed99 is offline
Old 10-24-2004, 01:31 PM
  #52
flnsx's Avatar
I am going my sell my 10000k bulbs that I have in my 04 TL.
In the black market. They look VERY VERY blue but don't give off enough light.
They are a week old from Autolamps GE 10000K Xenon Discharge D2S 12 volt 35 watt. See the black market
flnsx is offline
Old 11-27-2005, 09:24 PM
  #53
Usalinh's Avatar
Quick question for anyone out there. I just recieved a set of HID replacement bulbs from BlingLights.com and was sent a set of 10.000k DsR bulbs. I was wondering if this bulb is the same as the Ds2 bulb everyone refers to also in all the forums. I want make sure I got the right bulb before I put them in and try them out and notice they're the wrong bulbs. Thanks for any replies or answers.
Usalinh is offline
Old 11-27-2005, 09:25 PM
  #54
Usalinh's Avatar
Quick question for anyone out there. I just recieved a set of HID replacement bulbs from BlingLights.com and was sent a set of 10.000k D2R bulbs. I was wondering if this bulb is the same as the D2S bulb everyone refers to also in all the forums. I want make sure I got the right bulb before I put them in and try them out and notice they're the wrong bulbs. Thanks for any replies or answers.
Usalinh is offline
Old 11-27-2005, 09:42 PM
  #55
knighj1's Avatar
they are not the same the notches are different you need d2s or d2c, send them back they will not fit
knighj1 is offline
  #56
knighj1's Avatar
i have 12k and love them
knighj1 is offline
Old 11-27-2005, 10:39 PM
  #57
TeamXRSX's Avatar
All OEM's use 4100-4300k HID burners.
CJ
TeamXRSX is offline
Old 11-27-2005, 10:43 PM
  #58
TeamXRSX's Avatar
D2S is a burner for projector headlights, D2R are for non-projector headlights. The difference is that the D2R has a black coating on top of the burner to reduce burner glare and the D2S has no coating, as the projcetor limits glare above the light beam.
CJ
TeamXRSX is offline
Old 11-28-2005, 01:44 AM
  #59
ed99's Avatar
Pics would be nice to see what 12k bulbs look like.
ed99 is offline
Old 11-28-2005, 10:09 AM
  #60
Usalinh's Avatar
TeamXRSX - does it really matter if the bulb is for a projector or a non-projector housing? Jason from BlingLights.com asured me that there is no difference other then one is made for non-projectors and the other is made for projectors. And do you know if the notches are different like knighj1 referred to. I don't want to try and change out the bulbs and find out that they don't work with the housing and don't shine the way they're suppose to shine. Thanks guys for your infos...
Usalinh is offline
Old 11-28-2005, 11:18 AM
  #61
Registered User
rbf351's Avatar
there is a difference, the D2R has the coation to reduce glare, and the notches are different, they will not fit in the housing without modifying the bulb
heres a pic
rbf351 is offline
Old 11-28-2005, 12:09 PM
  #62
ARNGRIMMR's Avatar
If by 12k he means 12000k, it's black light.
http://faqlight.carpassion.info/hl-hid-bulbs.htm
(about 3/4 way down)
Purple:
28000 Northern sky
12000-30000 k Ultra Violet light (black light)
ARNGRIMMR is offline
Old 11-28-2005, 12:10 PM
  #63
TeamXRSX's Avatar
Like rbf351 said, there is a difference as i explained and now you can see with the pics rbf351 provided.
CJ
TeamXRSX is offline
Old 11-28-2005, 07:26 PM
  #64
caball88's Avatar
Purple:
28000 Northern sky
hahaha must be like a night club everytime he uses his headlights. but just so that some people dun get confused, HIDs often rated at absurd ratings like 10K+(and even some 8000K) are made by ghetto korean companies that do not obey any type of iso standard. so even tho they say 12K it is often just to market the color. the higher the temp the more extreme the color. If that bulb was accurate and was actually 12K then the headlights would be completely useless. it would be pretty funny if someone was actually using ultraviolet light in their headlights.
caball88 is offline
Old 11-29-2005, 02:50 PM
  #65
Purple:
28000 Northern sky
the number sure is getting higher and higher...
pretty soon it's out of the spectrum...; can't see !!
kaister is offline
Old 11-29-2005, 02:51 PM
  #66
anyone have troubles with the cops upon installing of these HIDs?
kaister is offline
Old 11-29-2005, 04:03 PM
  #67
NY/NJ TL Crew
arseny87's Avatar
I purchased a set of 8000K d2s bulbs for my tl but when me and my friends were going to install them, we noticed that we needed to take the bumper off! They look amazing though on our TL projectors and the 8000k is by far the nicest color, and you wont get a ticket because they are not as blue as 10000k. I am actually trying to sell the set of bulbs i have laying around if anyone wants, just pm me or email me.
arseny87 is offline
Old 11-29-2005, 04:44 PM
  #68
mio
Police
mio's Avatar
Originally Posted by NightRider
I asked the mechanic at MB dealership and he said they are 6000K for the E and S class. I am not sure about BMW's, but they definitely look make our lights look white with their blue hue. I think this is why they they are "options" and not standard like ours.
The dealer is lying, every stock car can only use 4300K hid, that is the law...
why it looks more blue or purple? different projector techology.
mio is offline
Old 12-03-2005, 08:22 PM
  #69
SSgt, USAF
Filip75's Avatar
so can someone say exactly what kind of bulb do we need to buy (never mind the Ks). What is the exact part number, and where can you buy them.
In my old BMW I had 6000K and they were perfect. And they were made by Phillips, so I knew that the quality was going to be good, vs. all those Ebay types. So... could someone tell me, what kind (brand, type, model) and where... Thanks
Filip75 is offline
Old 12-03-2005, 11:57 PM
  #70
caball88's Avatar
if you want to get a new set of bulbs you need d2s bulbs. if you really are after the color effect i would get the philips ultinon bulb. they are rated at 6000K. personally i like the stock, the color and brightness is perfect.
caball88 is offline
Old 12-04-2005, 10:33 AM
  #71
I like to mod teh Bimmer
sweetride01's Avatar
I can't be bothered to read the whole thread.
Here's what I can tell everyone:
All OEM HIDs are 4100-4300K. NO car manufacturer uses 6000K. The only decent bulbs are ~4300K ones and the 6000K ones, because Philips also makes the 6000K ones. Make sure you don't get the dyed bulbs - they are rip-offs.
Halogen light gives you the best visibility in the rain and foul weather. HIDs actually seem to light the road less well in the rain, and the higher colour temp you get, the worse rain vision will get.
I have 6000K Philips bulbs in my 1990 325iS, fitted into european projectors. The light is an intense, pure white, and I am very happy with them.
I used to want 9000K, but people told me they were lower quality, and I realized they are a bit ricer as well.
Blue light is very taxing to the eyes and will make you tired quickly when driving at night. Don't go above 6000K.
This website is EXTREMELY useful: www.danielsternlighting.com
sweetride01 is offline
Old 04-23-2014, 12:35 PM
  #72
J_White11's Avatar
I have 8000k D2S replacement bulbs in my 05 TL and I'm very pleased even though my headlights are pretty cloudy. Sorry no pics until I get my headlights wet sanded/ buffed that way you'll have a clear image of what they should look like with clean headlights.
J_White11 is offline
Old 04-23-2014, 12:51 PM
  #73
soupi's Avatar
30k Violet Purple(show purposes only) headlights and foglights on my Altima
soupi is offline
Old 04-23-2014, 02:03 PM
  #74
paperboy42190's Avatar
Received 1,162 Likes on 847 Posts
cool
paperboy42190 is offline
nate_0022 (04-23-2014)
Old 04-23-2014, 03:16 PM
  #75
MOBB's Avatar
HOLY THREAD REVIVAL! Really?? All for some 8000k bulbs with cloudy headlights!!
And the 99 Altima with 30k lights not cuttin it with the hubcaps man
Do it right with either some CBI's (5000K) or if you guys want some color I have the Philips 6700k on my 06 from imported from japan that puts out a pink/purple hue and doesn't look ghetto.
its not 2004 anymore the blue lights gotta stop.....
MOBB is offline
Old 04-23-2014, 03:24 PM
  #76
nttstt444's Avatar
I hate people that install 10000k + headlights. They look retarted and you cant see a damn thing. This thread just gave me a good laugh.
nttstt444 is offline
Old 04-23-2014, 03:40 PM
  #77
soupi's Avatar
it looks AMAZING! when driving on the road! lots and lots of compliments. I had some 19 konig wheels, it looked great.
soupi is offline
Old 04-23-2014, 03:41 PM
  #78
soupi's Avatar
dont get your little panties in a bunch, its a old picture!
soupi is offline
Old 04-23-2014, 03:56 PM
  #79
KBPftmfw
95oRANGEcRUSH's Avatar
Sorry, there is nothing amazing about a 15 year old Altima with purple headlights and foglights, hubcaps and tacky-as-fuck, stick on Autozone fender vents. The only compliments you got were from people with just as bad taste in mods as yourself.
95oRANGEcRUSH is offline
Old 04-23-2014, 04:36 PM
  #80
Chapter Leader
(Northeast Florida)
gatrhumpy's Avatar
Received 1,652 Likes on 1,117 Posts
There's as much useful light in 30K headlight HID bulbs as parasitus getting laid by a woman.
gatrhumpy is offline
Quick Reply: HID BULB 10000k (Purple Tint)
