HELP with seafoam
HELP with seafoam
I tried the seafoam today in my 05 TL and my wifes 03 accord v6. I took the hose from the manifold out and let it suck half of the bottle of seafoam. and i turn the car back of and plug the hose back and pour half of the seafoam in the gas tank, i waited 15 mins before i started teh car back up and rev so it would smoke. i sat there and rev the car for about 10 mins and no smoke would come out!!!! did i do something worng????
my wifes car didnt want to stay on for a while. i had to leave the car sitting there at idle with ym feet on the gas for about and hour. so it can burn up some of that seafoam because it wouldent idle. i then let it sit there at idle rev it and when rpm went down it cut off so i let it sit there at idle for about an hour. did i do somethign wrong? i watch the diy on youtube. and did what they did
U should try the process again in like 2months. But this time, sip it through the vac line, half of the bottle, make sure the engine is hot before u do this. Let the car sit for 45-1 hr. Then rev it a couple of times, and go for a sprinted drive. Most shitty cars smoke alot, i think its emberresing seeing our car smoke like an old crappy toyota.
I seafoamed mine twice in 2 days
First attempt I read the can so I used 1/3 a can. The engine was cold. No smoke. Either not enough seafoam or the engine wasn't warmed up.
Second attempt. 3/5th a can and hot engine. So much smoke the driver 100 feet behind me stopped. The cel came on for a minute and went off. The idle was really low, almost felt like it was going to stall. Kept driving for 2 miles doing spirited driving. Got to destination and parked for 10 mins. The car ran fine again afterwards.
In some cases, yes. But thats if u have over 100k miles on the car, and thier is alot of carbon buildup in the engine. But most likey not really, were u can actaully tell a diff.
there is a very good DIY seafoam in gen3 titled seafoam diy-specifically 05 (thats what is was tested/photo on, but its all the gen3)
Forget everything you saw on utube or read on the can and follow the well tested ziner method
1 can in intake vac port on top of intake manifold at TB throat
1 can in 1/2 tank gas (2oz per gal gas is cleaning doseage)
Be sure to spray clean the TB plate-both sides and edges- important!
Optional- 1/2 to 1 can in the engine oil 10-30 minutes running right before change of oil and filter
Warm up drive and immediate seafoam with engine running-
when done applying, then 5-15 minutes MAX waiting time with engine off
Keeping it all warm is key
The majority of the smoke is the oils in seafoam reacting to HEAT in the cat.
The carbon residue it very hard to see thru the mirrors while driving it hard afterwards to blow all the gunk out~
CEL is from not enough heat or hard drive, crud gets stuck on the o2 sensor but burns off and all is well
1st timers repeat in a month or 2 then good for a year/ 15k miles
Should start doing this at 50k miles
The additives in gas leave behind so much stuff- the cars performance suffers
bg44 and a few others are also good
csmeance
You dont have to FOG the engine with seafoam on normal cleanings- thats when you put some in slow then hit it with a long heavy shot causing it to stall.
Thats something you do before storing the lawn mower for winter or the car for several months,,or restoring an old dead engine (did it on my bike, worked great. lowered rpm by150-200 at idle! and smooth,,,has clean rings now~)
For the TL, do most of it at idle or slightly high idle, and according to the Deep Creep can (seafoam in aerosol form) you can do a 2500rpm blast to really get stuff done!
do that after softening and removing with the idle speed
Possibly do that as a second treatment after the initial and burn off drive- then hit the intake with 2500 rpm spraying and a short drive to clean the cat
non believers should see youtube vids of induction cleaning,,iirc wynss made it and there were others alongside- with a boroscope camera inside the engine while running and getting cleaner added
There is huge amounts of crud on everyones valves and piston tops
If you use gasoline to run the car- its there
THE MOST INPORTANT QUESTION IS. I seafoam my wifes car, "on cold" but i didnt knwo that you suppose to do it on warm. i did half in the intake vaccumm hose, i did shut the car off and pour half in the gas tank. i waited 15 or 20 mins to crank the car back up so i can rev. i rev the car for 10 or 20 mins stright. but didnt get a result in smoke. so i said fuck it. i went to drive the car around the block. the car kept stalling at low rpm. i did it for about and hour. so i parked it and kept reving the motor then i took the car for a spin again. it still kept stalling the car would shut off when my feet was on the brakes and the car was in drive. I said to my self.. "DAMN SHE IS GOING TO KILL ME" i drove it home thinnk why it wont idle normal. so i took the vacum hose back off so it can stay on so i can let it sit there and burn all that seafoam that was probilly causing it to stall and idle really low. i left the car running for an hour and then every thing went back to normal she said the car feels better but i couldnt tell a diffrents
lucky me i didnt get killed that day
acuratl26
04-23-2020 07:30 PM
EPS CL
06-02-2009 11:16 PM
manteuffel
03-12-2006 11:12 PM
