headlights
Photographer
headlights
anyone have pictures of how the headlight pattern should be? prefferably against a wall. i just installed a new set of bulbs and wanted to make sure they are adjusted properly. the reason i ask is beacuse the passenger side looks to be off.
now i have used the search function before i made this post and i kept getting this message. i got frustrated and gave up. thanks.
searched; headlight and headlights
Sorry, we were unable to fulfill your request
Reason: Your search returned a null resultset
Possible Causes:
You may have searched for a stopword. This is a word that is very common and would be removed automatically by the search engine (eg. I, am, me, a, the, etc.). Try adding additional terms to your search, or trying terms which are less common.
There may be problems with the search server. Try the search again, or try different options. If the problem is repeatable, please let us know and we will do our best to fix it as quickly as possible!
Possible Causes:
Check the first post in this thread. You will find a few videos of the light projection at different distances:
https://acurazine.com/forums/3g-tl-2004-2008-93/custom-headlights-jnc-641022/
AmplifiedDetails
09-24-2015 02:55 PM
