Harbor Freight 1.5 Ton jack enough
Old 08-02-2012, 06:52 PM
Bruce Banner's Avatar
I'm looking for a jack for the 3G TL.
Is a 1.5 ton enough?
I'm thinking it should be since it's not all the car's weight.
also does anyone know what the difference is in those three 1.5 T on models?
http://www.harborfreight.com/catalog...=aluminum+jack
Old 08-02-2012, 06:57 PM
BANNED
SharksBreath's Avatar
Received 2,885 Likes on 1,784 Posts
get a 2 ton minimum, 2.5 ton maximum.
I have a racing aluminum 2 ton jack from harbor frieght.
it's lightweight and awesome, I use it all the time. pick up 4 jack stands and a creepy crawler while you're there.
Old 08-02-2012, 06:58 PM
truonghthe's Avatar
Received 1,692 Likes on 1,307 Posts
two of them are the same model so the only differences is compact size versus full size.
Old 08-02-2012, 07:31 PM
Chapter Leader (Midwest Region)
McCollins23's Avatar
Don't get the one that only goes 14 or so inches. Will not lift the rear off the ground at the tow hook.
Old 08-02-2012, 07:36 PM
I'm looking to do the front mostly.
Jpipe, oil change etc..
the 1.5 T, is pretty light to carry around. I do understand I might be pushing it since the car as a whole is about 3400lbs
Old 08-02-2012, 07:42 PM
Steven Bell's Avatar
Received 6,470 Likes on 5,162 Posts
I need to get one myself. That way McCollins and swoosh won't have to bring theirs over all the time.....
Old 08-02-2012, 07:56 PM
YeuEmMaiMai's Avatar
1.5T is 3000lbs, more than enough to lift any side of the TL easily
Old 08-02-2012, 08:02 PM
That's at capacity, but for that to occur that would mean the front end is 3k lbs and the rest of the car is 400lbs, which my common sense tells me would not be the case.
I'm guessing realistically lifting the front is prob more like 2500lbs?
Old 08-02-2012, 10:45 PM
6spd FTW
Tehvine's Avatar
Buy a nice jack so you only buy it once. Get a decent low profile aluminum "race" jack for 2-2.5 tons with plenty of lift height. 18 inches is about the norm for one of the aluminum ones. I picked up a Crapsman 2 ton aluminum several years ago. Haven't heard anything bad about the HF ones either, they are a few bucks cheaper than the ones at sears.
Old 08-02-2012, 11:09 PM
I had bought the costco steel floor jack last month, it was like $100. great deal on a great jack, but the weight of it killed me. I returned it. That jack was just infeasible to carry from point A to point B.
That's part of the reason I'm considering one of these which are about 37lbs
Old 08-03-2012, 12:05 AM
TL-S
quanaman's Avatar
I have tw 1.5 ton cheap one. I think it's 69$ or something.
Great and lightweight aluminum but it doesn't lift the rear wheels which is annoying. It won't even lift the front high enough to get jack stands underneath.
Definitely get one that goes as high as possible. 14" isn't anywhere near enough ESPECIALLY For the rear. If you don't you'll have to get creative and find random jacking locations under the car which isn't fun or necessarily safe. Do it properly and get a jack that goes up HIGH. I sometimes have to use a wooden block between the jack and the car (not really safe)
I believe they have an aluminum one that does 17" which might be closer.
Old 08-03-2012, 01:29 AM
'07 TL Type-S
Healingduck's Avatar
I bought this one
http://www.harborfreight.com/25-ton-...ump-68049.html
It's a lot lower than I thought it would be, which is nice, and it lifts to a good height. I haven't tried lifting my TL to maximum height on it, but when I changed my oil it lifted it just fine with plenty of height to put the stands under. It goes from 2-3/4" - 20" Plenty of clearance with stock height. The thing is heavy though. Not something I will really take out of the garage.
That being said, I wouldn't get the 1.5 aluminum one you are looking at. You should get something that lifts somewhere closer to 20''. As far as the weight I think you should be fine. Especially if you just put it up on jack stands once it's up. I think you are smart getting the aluminum one though. lol
Old 08-03-2012, 04:27 AM
I use a 10 year old autozone 1.5T jack to lift the CL-S and it not failed yet. It's actually made out of steel :p
Old 08-03-2012, 06:43 AM
2014 Jeep SRT
ebelp's Avatar
Received 1,615 Likes on 1,030 Posts
If you plan on lifting the car from the front subframe, you need a jack that will reach. Your common aluminum racing jacks won't reach if your car is lowered too much. My car is pretty low, so I need something that's very low profile and has a long reach. This is the one I have and I love it. Worth every penny:
http://www.harborfreight.com/2-ton-l...ump-68050.html
Old 08-03-2012, 09:53 AM
the overexplainer
ez12a's Avatar
btw, axle weight is what you're concerned about, since you will never lift the entire vehicle with just the jack. 1.5 will handle one side of the car easily, but of course the greater the rating the larger the safety margin.
I've also been thinking about picking up a new jack since my father's only lifts about 14-15". The HF ones that go to 20" or higher are the ones i'm interested in.
08KBP_VA
10-22-2019 01:55 PM
copmagnet82
4G TL Problems & Fixes
06-29-2016 08:09 AM
navtool.com
3G MDX (2014-2020)
32
01-20-2016 11:43 AM
navtool.com
31
11-16-2015 08:30 PM
27trains
09-30-2015 09:44 AM
Quick Reply: Harbor Freight 1.5 Ton jack enough
