Hamilton Honda appointment
Good afternoon fellow AZ members.
I have an appt at Hamilton Honda tomorrow morning.
I'm going for my 105k service and I would be asking for this.
1 Replace Timing Belt
2 Replace Hydraulic Tensioner
3 Replace Tensioner Bearing
4 Replace Spark Plugs
5 Water Pump
6 Idler Bearing
7 Valves adjusted only if the technician feel it's noisy
8 Replace engine coolant
9 Oil Change
So my question would be:
What else would you recommend I get done now that the technician would be in there?
5 Water Pump
6 Idler Bearing
9 Oil Change
Received 6,470 Likes
What are they charging you, Vic?
Have no idea on price but as long as it's less then $1300 I'm cool.
"DeathMetal" would love to get a lightweight pulley but it's a little too late to order it.
Fearless DIY Guy
It's not. They do an insane volume of this service and simply have better buying power and efficiency. I've been there on 3 different occasions and, at a minimum, there are 3 or more TLs between the lot and bay at any given time.
Really. Any idea how much the would charge for a new clutch and flywheel?
Came back this morning from Hamilton, NJ and my experience is currently great.
My own personal Service Advisor just called my and advised me on a couple things that I should take care soon, really nice of hem.
I'm currently at $1139.94 with everything below included.
1 Timing Belt
2 Hydraulic Tensioner
3 Tensioner Bearing
4 Spark Plugs
5 Water Pump
6 Idler Bearing
7 Valves adjusted
8 Engine Coolant
9 Oil Change
10 Parking Brake Adjustment
1 Timing Belt
3 Tensioner Bearing
4 Spark Plugs
5 Water Pump
6 Idler Bearing
7 Valves adjusted
8 Engine Coolant
9 Oil Change
$75 for tensioner
$289 to adjust valves
Not sure on spark plugs, did it by myself
prices are from 6/15/2012
Sorry for the delay "Personal Vacation"
Here's my 'Invoice' with HAMILTON HONDA.
![](http://i11.photobucket.com/albums/a159/heartblackbnw/IMG_0245.jpg)
![](http://i11.photobucket.com/albums/a159/heartblackbnw/IMG_0246.jpg)
![](http://i11.photobucket.com/albums/a159/heartblackbnw/IMG_0247.jpg)
A little surprise I found once I came back home and back the car out the garage..
![](http://i11.photobucket.com/albums/a159/heartblackbnw/IMG_0222.jpg)
looks like a great deal but what up with two bolts laying there?
Good Deal for soo much work.
The parking brake is a bitch to do, took me a few hours to really figure it out, after doing the rotor replacement myself.... I only had very limited time in the mornings so I Attempted to readjust it, to the Factory specs.
rust builds up in the E brake assembly and springs,
BUT the Plugs job is something I would not pay for.
I found the NGK IZFR6K- 11 for $6 each
they over charged you - at $24 each plug, wow......
but They do GREAT work and the TECHS are Top notch.
How does the TL run after this service?
DeathMetal (08-14-2012)
"mrsimeon" the car run great, significantly better then before and it gave me a nice smile on my way home. I don't know how to describe it but it just pick up so much better and smooth.
Resident Dingo
I agree. Didn't see the rotors on his work order. I had to get mine resurfaced on my car before I sold it. Got them both done for $40 but I had to pull them off the car myself.. nbd. Was a rush job because I had a trip to Deal's Gap coming up the following day LOL
Not good to find two timing cover bolts sitting on the cowl. Would make me wonder what else got left out under the covers. I've heard many good things about Hamilton, but maybe the techs are getting rushed to pump these jobs out at such a reasonable rate.
