H11 on the foglight?
Old Jul 17, 2011 | 10:31 AM
J-ProX's Avatar
Is it alright to put H11 instead of H8 for the foglight on a 2008 acura tl type s? It's 6000k btw and do i have to worry about anything burning?? Thanks!
Old Jul 17, 2011 | 10:55 AM
RainSupreme's Avatar
H11 is equivalent to H8
guitarplayer16's Avatar
You can try it out.
If you're going with halogen bulbs, they won't fit.
You have to do some trimming on the tab to make it fit using a dremel.
You'd also have to watch the wattage, and I wouldn't recommend doing this as it could raise some problems with your electrical.
http://www.hyundai-forums.com/t55379...-to-h1139s.htm
Old Jul 17, 2011 | 12:01 PM
Bearcat94's Avatar
AZ Community Team
Originally Posted by J-ProX
.... It's 6000k btw and do i have to worry about anything burning?? Thanks!
6000k has nothing to do with wattage, it describes color.
So, no, that color won't burn anything. But, then again, neither will any of the other colors.
You want to check Wattage.
Old Jul 18, 2011 | 02:12 AM
Yvuru's Avatar
i bought a h8 hid kit for my car and was sent h11's. they work fine and use 35w. 50w kits are available too
Old Jul 18, 2011 | 09:27 AM
Guiltyox's Avatar
Though you're right about describing color, technically Kelvin is a temperature measurement .
Old Jul 18, 2011 | 01:05 PM
vladkarnafel's Avatar
UA7 NBP TL-S
H11 and H8 are cross reference for each other, you can use either...
Old Jul 18, 2011 | 01:35 PM
Very true if you're refering to HIDS, but halogen bulbs are a tiny bit different.
OP didn't specify, so, who knows heheh
Old Jul 18, 2011 | 03:56 PM
J-ProX's Avatar
OK I did put them on and it works fine!! I love the way it looks but i think its way too bright, especially when I'm planning on putting 8000k for my high/low beam. What do you guys think about this combination 8000k high/low beam and 6000k for the foglights? Thanks
BTW: These are HIDs!
Old Jul 18, 2011 | 06:35 PM
UA7 NBP TL-S
do all 8k so they match, there will be slight color difference cause of the lenses, and its never bright enough
they are fogs so u dont have to worry about blinding other drivers
Old Jul 18, 2011 | 08:23 PM
J-ProX's Avatar
I want that bluish color like the ones you have on yours. Is that 8k? BTW is there a way to clean the inside of the foglight lens? I kind of messed it up! Long story short, the lens is now actually fogged up lmao! I was thinking of just sticking a cloth through the socket and try to wipe the lens off. Is there any other easy way i can do this?
Old Jul 18, 2011 | 10:38 PM
swoosh's Avatar
takin care of Business in
ohh for crying out loud....google it dude....
kelvin (color) cross reference chart
you want 35W....55W might burn something....
if you have the accord fogs get H11 (or what the fog light provider mentioned)
Old Jul 18, 2011 | 11:11 PM
Bearcat94's Avatar
AZ Community Team
Yes. And (kind of) no. It depends on context.
Although K(elvin), even when related to the color of light, is coorelated to a temperature, it does not have anything to do with the temperature (i.e. heat) of the light output.
If it did, a 6500K bulb would burn at ~11240 degrees F. That'll get your housings melted. And your sheet metal. And brakes. And pretty much everything else.
Instead (as I suspect you know), K(elvin) with regard to light means:
.... The color temperature of a light source is the temperature of an ideal black-body radiator that radiates light of comparable hue to that of the light source. Color temperature is conventionally stated in the unit of absolute temperature, the kelvin, having the unit symbol K. ....
http://en.wikipedia.org/wiki/Colour_temperature
IOW - you'd have to heat an ideal black body radiator to ~11240 degrees F to for it to glow with a color of 6500K.
Old Jul 19, 2011 | 12:08 PM
UA7 NBP TL-S
I have 8k for low/high beam and the rest are LEDs hyper white. Idk about cleaning your fogs... how did they get fogged up? I would pour some solution into the fog that doesnt eat out the reflective part and clean it that way.
quanaman
Jan 9, 2023 07:33 PM
Jul 16, 2017 07:33 AM
eccen
Oct 12, 2005 06:00 PM
amadeus303
Aug 26, 2005 12:00 PM
