Goodyear Gatorback Belt
I wanna replace my serpentine belt with a goodyear gatorback belt, does anyone know the length and rib width for a 07' tls i tried searching for the correct size but im lost. Does good year even make a serpentine belt for this car?
Any help is appreciated thanks! |
Here you go....
http://www.goodyearep.com/ProductsDetail.aspx?id=3128
Click on product selector and you can enter vehicle and so fourth. For a 2007 TL whether S or not part#4060840 length of 84.00 inches and 6 ribs. Randy B |
^ it is also for 2004 to 2008 TL
my question is why? The stock belt should last until 105K. Also if you plan on replacing it yourself, you may end up with a bad pulley tensioner, I have seen many instances where people go replacing belts and break the pulley tensioner. Use the proper tools when doing it.
you just need a 1/2 or 3/4" breaker bar right? And my belt i believe is squeaking.
Originally Posted by Lazer187
(Post 10193844)
my car i guess was manufactured newer before the ps pump recall happend.
(Post 10193916)
no its automatic.
