Gas Mileage TIPS and CONTEST
#81
I'm gonna save you all some trouble
THE BIGGEST THING YOU CAN DO TO GET BETTER GAS MILAGE IS TO DRIVE LESS AGRESSIVELY.
with the TL there is absolutely NO reason go go above 2.5K on the tach in city driving...even getting on the freeway I rarely go above 4.5K
Other things that will help
proper tire pressure
clean air filter
use the right oil for conditions and change it as recommended (definately put a new filter on)
don't wait til the last second to get off the gas and brake.....coasting and anything above 1500rpm = fuel cut (ie not pulsing the injectors)
Mythbusters already disproved the car being sooth = better gas milage (search on golfball car to see what I mean)
02 CL-S
5AT
100K
city 23
highway 30 @72
clean air filter
02 CL-S
5AT
100K
city 23
highway 30 @72
#82
I wish I could point you in a direction where this was stated as a scientific fact, but I cannot and am not going to go searching for same at this time. Let's assume you have three people in a car with the windows up and recirculate selected. These people are going to be consuming oxygen and creating carbon dioxide, not to mention that each one produces an average of 110 BTU. Add to that the fact that our entire skin surface also breathes. Now granted, even with a closed cabin, a small amount of outside air will make its way inside due to seals not sealing completely, body shapes and angles, and a few other factors. But these three folks are still going to be consuming oxygen faster than it can be replaced.
It if is just you, then you have more of a buffer, but I know for a fact that you are at risk of fogging up windows because I see it rather frequently.
Bottom line is, use your fresh air setting as much as you can. You lose virtually nothing and gain pretty much everything... unless a freshly dead skunk is lying in the road up ahead.
#83
i am at about 22-23 MPG in my car... i do a mix or city/highway daily--- i installed a K&N air filter to try and help with more MPG. friend has one in her TL & said it helped add about 3-6 more MPG! we shall see. that thing was $60...
#84
the only issue with this is the chance for rocks to fly up and cause damage.
id rather get less gas mileage and have a flawless car then save a few bucks on gas but have nicks in the paint from rocks.
#85
www.colradodetail.com
Been awhile since anyone posted here. I decided to look at my stats on my car today and here is what I saw. This is a mix of driving and trust me I love flooring it every now and again.
![](http://i1207.photobucket.com/albums/bb461/solech65/87BA7CBD-BA56-4C23-A10A-1C6D6FF688A9-3083-00000409CBF21EEF.jpg)
#87
2021 RDX A SPEC
I drive 60% hwy and 40% city per week.
Amazing to get 560km (apprx 348 miles )out of a single tank! Filled up at this point and had 2 gallons left.
I don't drive aggressively but every now and then when the hwy opens up...I let loose.
08 6MT-S gets better mileage than my 08 5AT TL
![](https://img685.imageshack.us/img685/746/1354492799773.jpg)
#88
So here's a question, let's say you're sitting outside in your car waiting for someone for around 8 mins. Does it save more gas to turn off the car and then turn it back on when they get in the car, or to just sit with the car on in park?
#91
If main goal is to save gas then buy a car that is just for that.
#92
If you go that route at lights leave the car in neutral if you have an auto- much easier to get going again quickly and car starts in neutral too.
#95
^ But 168 miles and getting 34MPG is more impressive than 29 miles for 36MPG. Even a short downhill grade will skew a 29 mile run. The best I have done is 34 MPG for 44 miles and an average MPH of 66. I have had lots of 32MPG runs at 400+ miles.
#96
it's not 36mpg, it's 38. However I know people would doubt me as soon as I posted it up, but I guarantee you it's not a downhill road. It was the 60 west freeway from riverside to LA, ask anyone from around here, it's not downhill, it even has an occasional slight up/down. anyways, it was only 29 miles because I made that 1 trip, I would have driven longer but I was already at my destination.
#97
#99
so you want to drive like an asshat in the city? 2.5K gives you enough grunt to move along nicely...
driving a CL is nice quiet comfortable and relaxing and so is the TL
my main goal is to save wear and tear on my car that i paid good money for and driving conservatively does just that........along with getting me great fuel economy for that car....
#100
Letting my TL shift between 3.5-4K makes me an asshat? I drive this car the way it was designed to drive, what to save on gas use bicycle.
#101
Honestly I do like the whole part where I can drive it to get even into the area of 30 mpg in city, but if need be I can quickly get up to speed/pass someone. My
#102
and yes constantly running the car up to those rpms in the city where traffic is congested = asshat...
"derp derp well the car was meant for that derp derp"
![ugh](https://acurazine.com/forums/images/smilies/ugh.gif)
#103
It seems that every time I post on here my mileage gets worse
-23.5mpg
-auto
-2008
-94
-ontario
-40F
-avg 30mph
I was getting 26mpg on 91 a while ago, it went down so I went to 94 and it made no difference still at 23mpg. Just before this I was getting 29mpg on 93 while I was down in the states where its warmer.
-23.5mpg
-auto
-2008
-94
-ontario
-40F
-avg 30mph
#104
the overexplainer
gas is getting a bit cheaper now with the winter blend and all. I'll try to start filling up completely and logging. Been only putting 10-20 each time. I suspect i'll get mid 20s.
#106
I get 400 miles on every tank just driving to work & back here in Vegas (50/50 freeway & city). Granted our traffic light network is quite advanced though.
#107
Keep Right Except to Pass
There's no question that it's doable and that if you do a full tank out on the open highway (no traffic jams or roadwork delays), you ought to top 400 miles unless you find yourself in the mountains where you might be using lower gears a lot. My record is 455 miles on a tank. I haven't beaten that because usually if I stop for lunch I'll just fill up the tank then, regardless of mileage, to avoid the nuisance of having to make another stop later (or, if I will be passing through New Jersey when I might need to fill up, I make a point of filling up before I reach Jersey because of their stupid "no self-serve gas" law).
#109
I believe I took this picture in Emporia, Virginia, in July 2011. We were on our way back from Florida. The low numbers for distance and time are because I reset the trip computer each time I fill the tank (after noting down the price per gallon, trip meter, odometer, number of gallons/litres, and the mpg and mph numbers).
![](http://i31.photobucket.com/albums/c378/1995hoo/24dcbe96.jpg)
#110
-mileage you are getting: 25 city/ 30 hwy
-auto or manual: manual
-year car: 2005
-grade of gas: 93 octane
-where you live: Las Vegas, NV
-regular temps: 60
-highway or city driving ratio: 90 % highway / 10% town/city
Tips:
-open windows/moonroof instead of A/C when possible: Living in the upper Minnesota, open widow is the best AC in Spring and Fall choices
-use cruise control when you can: Too much traffic where i live, over 400,000 people using these highway. Saint Payl/Minneapolis.
-take off from a stop slowly: Shift below 3K RPM
-switch from 1st to 3d etc when possible: Never.
-get into 5th or 6th gear asap: If I do city driving, I stay in 3rd gear since speed is 30mph. Highway, you just have to go traffic speed.
-for manuals put into neutral and cruise up to stop signs and lights or if you see traffic ahead: ? im confused
Can anyone think of anything else? Use some free flowing mods to free up some air in the engine such as jpipe, exhaust to get better MPG.
-year car: 2005
-regular temps: 60
Tips:
#111
This statement is the complete opposite of what you should do. If you keep the car in gear while coasting, the injectors are completely shut off thereby reducing consumption. Also I believe it's possible for drive-by-wire throttle systems to reduce pumping loss during off-throttle deceleration by leaving the throttle plate cracked open while the injectors are switched off (less engine braking effect). Though I have no idea if Hondas are actually programmed to do this or not.
#112
#113
At least in my M/T TL, fuel cut won't start unless the engine speed is above something like 1,300-1,400 RPM. It's a bit picky until you pass about 1,500. Changing gears and never touching the gas after changing results in less aggressive fuel cut, until you touch the gas again and let off or are at sufficiently high RPM.
It's typically really easy to tell when its cutting fuel. I have no experience with this 'grade logic' system, but I would imagine it decelerates the car by cutting fuel and braking by using the engine to pump air. Most every modern vehicle has some sort of fuel cut system, some are just less aggressive and less noticeable. If you snap off the throttle above 45-50MPH, you should be able to distinctly feel the engine output reduce, and then the driveline unload as the injectors are cut and the torque on the transmission reverses. Don't touch the throttle until the engine slows down to about 1krpm and you will feel the fuel cut stop. The slop in the driveline as the torque reverses again will give you some feedback as to when this happens. You might notice a slight fluctuation in the tachometer reading when this occurs.
I didn't read most of the thread, but everything the OP said is wrong.
#114
![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
Same way you can bump-start a manual car by pushing it down a hill and then releasing the clutch in gear once it's rolling fast enough.
08_UA7_Gr33k
02-11-2016 02:17 PM
