G-049: Back up lights too dim!
#44
Weapon X
Yeah Im with PeterGrant, shipping them back probably wont be worth it. So I took a little more time to find the correct ones and found them a little cheaper
http://thepartssite.com/Merchant2/merchant.mvc? $10.87
but it may be easier to call them to get it verses login on and all that.
#45
Moderator Alumnus
Originally Posted by RawDogg
Sup folks.... I doubled checked the bulb case last night, and sure enough they were not the 7440. They are PIA19224 - W2 as stated by KBOM.
Sorry 'bout the mix up...
#46
Here are a couple of direct links.
http://www.carolinaclassictrucks.com...lbs/piaa-19224
http://thepartssite.com/Merchant2/me...Category_Code=
#48
Team Anthracite #100
RawDogg- It's all good. Honest mistake.
Nodoze2004- Not sure if I read your post correctly, but the front marker/turn signal is a 7443 style bulb.
Maybe this will help someone........(my findings thus far)
Front turn/parking bulb(2ea): 7443
Rear turn bulb(2ea): 7440
Reverse bulb(2ea): 921
Fog lights- US model(2ea): 9006
Ceiling(4ea): 2825
Doors(2ea): 194
Trunk(1ea): 2825
Vanity mirror(2ea): 2825
license plate(2ea): 168
Glove box(1ea): ???
Center console(1ea): ???
Brake, side markers and high mount stop: all L.E.D.
The 2825, 168, and 194 are all the same size with different wattage.
5watt, 4watt, and 3watt respectively.
I'm having trouble with the glove box and center console. Manual says they're
1.4watt
Ceiling(4ea): 2825
Doors(2ea): 194
Trunk(1ea): 2825
Glove box(1ea): ???
1.4watt
#51
I'm Baaack!
Originally Posted by 04AcuraTL
n e one think of puttin clear LED"S?????that'd be something interesting
#53
I'm Baaack!
Originally Posted by Lokius
any pictures of this install yet?? Really interested to see if there is much of a difference, I also need some help with the install..
Good news, bad news about the lights, I can tell you having the reverse lights on against the back of the garage they did appear brighter, however I can honestly say I didn't see too much of a real difference backing down the driveway.
Lokius what are your questions about the install?
#54
I dont really like the location of the reverse lights on the TL... my thoughts on a possible solution:
Smoke that whole plate around the license.
I think that'd look really nice on a black. You'd have to get bright bulbs for sure though.
#55
I replaced mine with a set of PIAA Extreme White bulbs. It's a clean white with a blue-ish tint to it...they work wonders, and they look much better than the crapy stock yellow!! I'm not too sure what the exact wattage is as I would have to go dig up the box, but they only cost about $15....
I'm sure your local Custom Car store would have some....
#56
They're 6600k PIAA HID Bulbs.... Real HID bulbs, but give more of purple/blue-ish tint like an Audi/BMW.
Stock HID's come with 3500k (i think?)...these just bump up the richness of the color. In actuality, they make the stock HID look like a stock yellow light when compared side by side....
If you check out PIAA 's website, you'll find more info there...
#57
Team Nighthawk MechE
Not sure if everyone checks the photo gallery as much as they do here... Just to cross reference... Here are some pics from someone:
https://acurazine.com/forums/showthread.php?t=107401
Here is the link to the bulbs he bought and used:
#58
could someone who has installed the PIAA W2 confirm that it is in fact a wedge style bulb as pictured on various websites and also, is the stock reverse light bulb a 921?
i ask this because on my 2K maxima, i have 921 style reverse light bulbs and they are twist in and NOT wedge style. maybe there are two types of bases for 921 style bulbs. looking for the truth.
#59
one other thing to add is that some guys have retrofitted an H3 bulb, (35 watt and even 110 watt) into the maxima's reverse light socket for really bright lights that actually produce a rearward beam.
how this affects the wiring remains to be seen but if you live where it is pitch black this sure would come in handy as long as it doesn't melt your wiring, which it cetainly could with very high wattages.
#60
Originally Posted by Crazy88
How much would labor run or is it an easy DIY?
#63
I'm Baaack!
#64
I'm Baaack!
To those who still have questions.
Open the trunk, and working your way in from either side:
1) remove the bump stop (round black cork looking thing) by twisting the entire stopper counterclockwise
2) remove the black strip (there are three points on the back) you remove it by popping the outside edge and then sliding the entire strip towards the outside.
3) remove the trim piece over the lock mechanism (it just slides off)
4) repeat steps 1 and two for the other side
5) You'll see the trunk panel is held on by several (I think 11) small black plugs. These are two piece units, pull out the center and the entire plug will come out similar to a dry wall anchor. You'll need to pull out 4 or 5 to get your hands in between the liner and the light assembly.
6) Ease the liner down over the lock.
6) Light assembly comes out with a quarter turn and a pull, then the bulb is removed by pulling straight out.
Reverse to re-install I broke two of the little black pklugs on removal, they cost $1.04 each at the local dealer. Aside from that this one was a no brainer.
Hope this helps.
#65
#66
OK. Got The PIAA w2. Install was fairly easy. The light is whiter and a bit brighter than stock when you are looking at it from the rear. Sitting in the driver seat and backing up, not much difference.
#67
i need BRIGHTER arrgh!
#69
Hey guys. I just finished putting in white 9 LED lights for the license plate, and the PIAA bulbs in the backup lights.
They're great. While they're not a lot brighter, I think they do give off a bit brighter and a better light.
Two shots to compare the PIAA and stock bulbs:
And the two together:
Once the trunk liners is out, it's easy to do both in a just a couple of minutes.
When putting the trunk liner in, you might not want to leave the one screw to last, even though it was the first thing I took out.
#71
Moderator Alumnus
PeterGrant, they look great... I thought those pics are all from the new PIAA bulbs, right?
Which one is the stock bulbs' pic? Thanks.
#72
The first two pictures (without the license lit up) compare the PIAA bulb in the left and the stock bulb in the right.
The last two pictures (with the license lit up) have both PIAA bulbs and the 9 LED white LEDs in the license plate.
#73
Has anyone changed the turn signal bulbs to PIAAs? (Since I ordered the wrong type for the backup lights originally, I have a set that I think fits).
I'd like to change the DRLs too, but I think that's likely beyond my mechanical skills.
#74
Moderator Alumnus
Part Number: PIA19224
Bulb Type: W2
Wattage: 18w
Technology: Xtreme White
What's your 9 LED white light? Thanks.
#75
.:KCCO:.
#76
Originally Posted by rets
Thanks. Did you also use this?
Bulb Type: W2
Wattage: 18w
Bulb Type: W2
Wattage: 18w
Yes, those are the bulbs I used. The really do look great. I can't measure the difference, but my impression is that they are brighter than the stock bulbs. (Unlike the 9LEDs, which are not as bright as the stock bulbs.)
I bought the white 9LED bulbs from tec_toyz.
#78
PeterGrant,
Thanks a lot for the pictures!!!
If possible, could you please try to put the White 9LED Bulbs in the front center console (right next to the sunroof) so that we get a better idea as to how the WHITE LIGHTS inside the car would look...someone had previously put blue lights and they looked really nice, but I really would like to see how the WHITE LED's would look inside the car...and I'm sure others do too...
Thanks, in advance
- I got those PIAA reverse light bulbs and I'm going to install them this weekend...i can't wait!!!
Thanks, in advance
#79
9th Gear
Cool but some work involved
I changed my bulbs last night, took me about 1/2 hour to change them out. There one screw you need to remove for plastic holder to the right of the locking mechanism. REMEMBER THAT and you'll cut your install time in half.
Anyways I the PIAA's are not brighter just cleaner looking. You can see the stock bulbs when backing up in drivers seat; however, the PIAA's you can't really see - they're a bit dimmer than stock but they look really nice.
#80
2005 TL Owner
Thanks for all the information. I got the lights and the checklisk of installation from this thread and installed in about 10 min:
Bulb Type: W2
Wattage: 18w
The little popup-pegs are easy to remove. Just use your finger nails to grab the popup and pull it out. If the larger piece does not come out easily, just apply light pressure with the liner and it will pop.
IMO the lights are a bit dimmer than stock
Here are PiCS:
New and stock in the light
New and stock in the dark
New and stock in the dark, dispersion pattern and color
Both New Straight
Both New Offset
Bulb Type: W2
Wattage: 18w
Here are PiCS:
Both New Straight
Both New Offset
