G-031: DIY Accord foglight mod without removing A-Spec and bumper
#201
hey guys, i have a noob question and maybe someone can help. i found these slim fog light hid kits and it says it doesnt have ignitors. Now is that a good thing or would i have to buy ignitors if i bought this fog light hid kit? many thanks in advance.
http://cgi.ebay.com/ebaymotors/ws/eB...20573606059%24
#202
Jokerman
#203
You can order the switch from the following website (it's #7 in the diagram):
http://www.thehondapartsstore.com/he...All&vinsrch=no
part#: 08V31-SDA-1M035
#205
ok, so i found these accord fogs with the hids as a package on ebay. i asked the seller if the lens are glass and if they aren't will they melt the lens. I got a response saying the lens are a hard plastic and with these hids they won't melt the lens. i'm a little skeptical and looking for opinions.
http://cgi.ebay.com/ebaymotors/03-05...Q5fAccessories
#206
Hey guys, anyone can give me a link of where i can buy the whole set of the accord fog light kit? and will that kit include everything i need to be installed or do i still need more wire to do so? thx
#207
I have an 04 TL with an 07 Bumper with stock Acura fog lights on them. Since it's an 04 I don't have any wire harness for fog lights at all.
I already purchased the Accord Switch (08V31-SDA-1M035) and the Switch Wire Harness (08V31-SDA-10030)
Do I need to get the Accord relay as well or should I just get any type of relay? How many do I need?
Will the Fog Lights wire harness for the Accord work on the Acura Fog Lights? Are the connector going to match on the fog light itself if I use the Accord fog lights wire harness?
Thanks in advance.
Thanks in advance.
#208
TEAM_SONIC
I already purchased the Accord Switch (08V31-SDA-1M035) and the Switch Wire Harness? (08V31-SDA-10030)
Thanks in advance.
Thanks in advance.
http://www.hondapartsnow.com/genuine...SDA-1M035.html
Is this the correct site for the Switch Wire Harness? (08V31-SDA-10030)
http://www.hondapartsnow.com/genuine...SDA-10030.html
I'm on the same boat as KamoteQ. Any input would help. Thanks.
#209
TEAM_SONIC
#210
anyone that can give me some help on this mod? im trying to get it done today or tomorrow. If you can would you please pm me so i can either call you or come help me? lol
#216
2004 TL foglight mod question!!
I am trying to do the honda accord fog light mod in my acura tl 2004. I have metal behind the right hand bottom mesh grille! How has anybody gone around this in order to install the lights??
#218
University of Tennessee
There is a meet some guys are going to. If you go, I'm sure one of the guys there could help you. I'd bring some tools just in case.
Here's a link to the Georgia thread.
https://acurazine.com/forums/southeast-318/%2A%2A-official-georgia-chat-thread-%2A%2A-796061/
Here's the info. More people than this are actually going.
Day-b4 Spring Meet
When: 03.19.11
Where: Taco Mac - Perimeter
1211 Ashford Crossing
Atlanta, GA 30338
Time: 12PM - 1PM time frame
1. donnieb83
2. rossv1
3. bukjoe15
Day-b4 Spring Meet
When: 03.19.11
Atlanta, GA 30338
1. donnieb83
2. rossv1
3. bukjoe15
#221
Can someone tell me how to aim these? I had them installed at a shop yesterday and when I turned them on tonight they were shining on the houses as I was driving down the street. They are aimed too far to the right and left and too high; they were shining on the second story of the houses???? Can someone help?
#223
2006 TL: WDP/Ebony
#224
#226
Ok well i took a picture, just so i can be 100% sure what im doing
In this picture there are 3 connectors on the left ( 2 go to the 2 different relays right? ), but what about the skinny and long connector where does that go?
There are also the 3 wires on the right, what do i do with them? I read the accord installation guide but it says to plug them into the connector on the relay box? (i doubt its the same for the TL?)
#227
2006 TL: WDP/Ebony
^the skinny connector with 2 wire: the green wire will be ur tap that you will have to run thru the firewall and splice to the green on switch harness
on the right (3 wire), u only need to use the red/blue to an inline fuse for constant power.
hope this helps
hope this helps
#228
Oh okay
- So i cut the green off the skinny connector and extend it in through the firewall and then connect it to the green wire on the connector that the switch plugs into.
- Then the red/blue one, I have to connect it to the battery. So I gotta add wiring from the battery run it through a in-line fuse, to that wire.
- The other two connectors which connect to the two relays, do the relays both get bolted in at the same place? or is one inside the cabin? Does it matter which color relay is where?
#229
Okay and let me see if i got the rest of this.
On the switch
- The blue wire taps into the parking lights, to give it power?
- Black is ground
- The red and red w/ black stripe are not used
so i do not need to use the rest of the connectors right? i just need the switch connector and the wires comming out of it, correct? should i just rip it apart and remove all of the other connectors since they are of no use to me? there are 5 connectors and by the looks of it i just need the one that goes to the switch
and can someone tell me which is the parking lights wire that i have to tap?
On the switch
- Black is ground
#230
2006 TL: WDP/Ebony
Oh okay
#231
2006 TL: WDP/Ebony
On the switch
- Black is ground
On the switch
- Black is ground
below the knee panel, look up towards ur left, its the connect w/ all red wires. look for the black part of the connector, its the red/black wire..or a quick way is use a test with the park lights on..
#233
^ u could remove the other connectors or just leave it, cause it is looped good.
#235
i seriously doubt it makes a difference if i go from a higher gauge (Like what the wires that come with the harness are), then to a bigger 16 gauge which i bought and am using to extend the wires, then back down to the higher gauge wire. Shouldnt make too much of a difference
#238
04 A-TL 6MT SSM/E N/Navi
On the switch
- Black is ground
On the switch
- Black is ground
#239
i want it wired so when i turn my parking lights on, then the switch gets power and i can turn the fogs on and off with the switch. But when i turn turn the parking lights to off. Everything goes off. Was i wiring it up correctly or do i have to do it a different way?
