Fuel pressure port for 2007 Acura TL
Where or how do I hook my fuel pressure gauge for 2007 Acura TL ? Need to know if I have fuel to the engine. I know my fuel pump works because I can hear it at the gas tank. But no sure if fuel getting to the engine.
Ate you having issues starting? Have you completely ruled out battery and starter ?
Welcome to the forums.
Since this is a technical issue and not a "New Member Introduction" I moved this thread to the appropriate subsection so you can hopefully get more help.
My starter turn and ignition I assume is good. I do have all the tool just couldn't find where to connect it. Don't see quick connect under the cover unless it in the manifold . I'm not sure what under the cover mean.
Need help where to connect fuel pressure 07 TL
my car dies while driving. I checked battery, starter turned which mean ignition switch is good. Need to know if fuel going to the engine hence I need help to find the quick connect the pressure gauge. Thank you.
Did you check for any codes with an OBD-II reader?
OTT3R
02-10-2017 08:04 AM
