Foot Well Lighting
#41
So DWB here is my plan, just wanna triple check before I start. Iv got a red nos switch that used to be used for my KC Daylighters on my truck. Ill tap into the parking light fuse, run all my wiring, find a good ground bolt, and whenever my lights are on the footwells will light up. Correct?
Use the Add-A-Fuse and throw in a low amp fuse...5-7.5A should do.
Also, you may want to use disconnects on the strips for easy removal...especially on the driver's footwell, since you have to mount it on the removable panel, which I find has to come off for just about anything you do electrical. Makes it easier to deal with in the future.
Good luck---post pics!
#42
Subscribe to this, when I get it done ill post up pics ASAP, have not ordered anything yet. Clay baring the car is first on the light right now, gotta get it all sealed up for the winter
#43
I may look into the rear dome thing. I'm not going to do something fancy like colored LEDs or anything. I'd just like to have courtesy lights in my foot wells. Seems like this is the only car I've had that didn't come with light there for some reason, I just miss it.
#44
Received 6,470 Likes
Guys, here's mine-I had the underdash LED's installed by a local auto custom stereo place.
![Name: 100_3952.jpg
Size: 27.8 KB](https://acurazine.com/forums/attachments/3g-tl-2004-2008-93/54209d1501299125-foot-well-lighting-100_3952.jpg)
![Name: 100_3950.jpg
Size: 35.5 KB](https://acurazine.com/forums/attachments/3g-tl-2004-2008-93/54210d1501299125-foot-well-lighting-100_3950.jpg)
I'm not sure how they wired this in, but mine underdash LED's come on when I turn on the headlights-just like the original underdash bulbs do in the front.
![Name: 100_3951.jpg
Size: 44.4 KB](https://acurazine.com/forums/attachments/3g-tl-2004-2008-93/54211d1501299125-foot-well-lighting-100_3951.jpg)
![Name: 100_3816.jpg
Size: 28.2 KB](https://acurazine.com/forums/attachments/3g-tl-2004-2008-93/54212d1501299125-foot-well-lighting-100_3816.jpg)
You can also see my illumiinated door sills and my red door bulbs.
#45
Buy some 18 Gauge wire. Thats the largest that will fit into a fuse it will also make the LED'S much brighter. Then you find a bolt or peice of chasis to ground them too. I used a screw in the fuse box area on my 02 you put the wire around it and tighten the screw. Now you find a fuse that almost always gets power I chose the instrument lights fuse you could use the security or theft deterent fuse if you want too that way you dont have to have the car either on or in battery for them to work. I bought 3 inch led strips straight from the streetglow website glad i did they look great. I have some mounted in the rear window too. when you put it in the fuse box btw use pilars to get the fuse out but be very care ful you dont want to crus the fuse but it will take some force to get it out then shove the wire in the middle between the two prong and force the fuse back in. BTW if you do it just like i told you you shouldn't electrocute yourself you thinking of adding a switch cuz i can help with that too so they arent always on
#46
Steven Bell where did you get the sills and do you know if they come in green?
#47
#48
Aww too bad thanks though
#50
PZ is correct-these door sills are not made anymore. I bought mine off the Black Market section of Acurazine. People sell them there from time to time. I posted a "Wanting To Buy" thread on the Black Market and someone responded to me! But you'll never find them in Green.
Thanks !!!
#51
K well thats disappointing but thanks for telling me so i dont go on an wild goose chase.
#54
#55
Good luck with that guy. I tried emailing him on several occasions with no response. He may have created a few sills (one of which is in white and looks sharp), but I don't think he is doing them anymore.
#56
Hey dwb I picked up some Goo-Gone today to debadge my car, I know the steps, head it up, tooth floss, and goo-gone. But do you have any tips? Im really affraid of being able to see where they were on the white car.
#57
Not really. Resist the temptation to scrape anything away (fingernail, whatever). If anything gets stubborn, just let the Goo-Gone soak in a bit more and go at it again.
Make sure you apply a coat of wax when you finish, as the G-G will strip the old coat.
It is a possibility that you may see an outline. You can try a light polishing/cleaning agent to try to get rid of it. I'm no expert on it, so you should do some research in the Wash & Wax section if you're concerned.
#58
Iv been reading alot of mixed results but it seems like the negitive ones are people and scrapped at the glue to get it off. I planed on just takin my time and letting the goo gone do the work. How well does that stuff work?
#59
Ill tell you the best cleaning product i have ever used on my car is called quik n brite its for like around the house stuff but a guy hit my door with his car (idiot was dumb enough to leave his car there after he did it, driving around with a fish sized dent in his driver door now) so had red paint and it wasnt a little hit either like he slammed his door against mine some of that stuff on a sponge took it right off. that may help..
#60
and btw i would have bought those white door sills anyway would have gone with the color of the car and still would have looked great! I am curious where the sills get their power though
#61
I couldn't let Steven Bell hog up the thread with his red TL-S goodness
, so I thought I'd throw a few more blue shots for the base TL crowd (Forgive the dirty floor--didn't have a chance to vacuum this weekend):
All lit up!
![](https://acurazine.com/forums/picture.php?albumid=1920&pictureid=22189)
![](https://acurazine.com/forums/picture.php?albumid=1920&pictureid=22190)
I could only score a set of the red doorsills (I would have preferred the blue) but they don't look too bad.
Footwell strips only:
![](https://acurazine.com/forums/picture.php?albumid=1920&pictureid=22191)
You can see my switch in the lower right of the dash---I still have to mount it!![Tomato](https://acurazine.com/forums/images/smilies/tomato.gif)
![](https://acurazine.com/forums/picture.php?albumid=1920&pictureid=22192)
Strips themselves:
![](https://acurazine.com/forums/members/dwb993-179691-albums-blue-leds-installed-1920-picture-fw-strip-22193.jpg)
![](https://acurazine.com/forums/members/dwb993-179691-albums-blue-leds-installed-1920-picture-fw-strip-r-22194.jpg)
With those shots, you can see why I said you need to get nice pedals if you do these lights. One mod leads to another, and another, and another.......
Finally, a shot of my de-badged rear for Crestwood.
All lit up!
Strips themselves:
#62
Im confused i thought you had red leds?
#64
I had blue for a while but gave up cuz i broke 2 of them and they were shitty autozone pilot brand so i spent some real money and bought them from streetglow, green to match the cars dials and stuff and they work real well my mom says I am trying to build a pimp mobile. Bitch
#66
DWB-those look good brother!
#69
DWB, thanks for the pic of the rear lol im sitting in microsoft word class right now haha senior year man. I cant wait to get home and work on debadging, its a nice sunny day for it! Im wondering, how did u wire the rear seat lights, did u just hide the wires or did u take ur interior apart? Second did u connect all 4 to one switch? Can I just get alot of wire and extend the wiring with a cripmer on each connection of each light?
#70
DWB do you live in mechanicsburg? My aunt and uncle live down there I go down most weekends. They live 2 mins off the carlisle pike. Did you put two bars under the drivers side? Whats that pic of, the last one above the pic of the debadged car?
#71
I used only one LED strip per location. The picture you ask about is a shot looking toward the face of the rear seat behind the driver. It shows where I mounted the strip on the front edge of the seat itself.
I used speaker wire for my connections and I was able to tuck the wires under the rear seat nicely---no need to remove anything. I ran them under the door sills to the front to make my final connections. All strips use disconnects to make replacement easier.
All 4 + leads go to the ACC point on the switch, all 4 - leads PLUS the - from the switch go to ground and my fusetap goes to the POWER point on the switch. Here is a diagram: http://www.oznium.com/rocker-switch/tech. Pretty simple stuff.
#72
Ah ic ic, if I ever end up getting a KP roll up or anything labor intensive id be willin to pay ya to help me put it in, i think your the nearest member to me lol. Mechanicsburg is a hour a half from here
#73
That's where my rear seat LED's are mounted too. The LED bar sits under the rear seat-against the kick plate (the mount/platform that the rear bench sits on). That way, the LED's don't get kick underneath the front seats.
#74
Dwb lol effem seriously and I have the same set up in the back seat. I have 2 green neons under front and passenger seat. and 2 3 inch leds on the rear window that shines down on to the rear seats
#75
Crestwood: The KP module is an easy install.
Steven: That's exactly why I did not use underneath the front seats. My kids would tear that apart in 20 seconds flat.
Saint: I dunno if I could take a couple of green LEDs shining down in my rear window/mirror. I have a helluva time with my CHMSL leaking red light down the inside of my tinted windows!
#77
LOl yeah I can understand they are actually illegal to drive with so I drive with them off or if i am carting friends around on its whatever. but they can get bright esspecially in the middle of no where
#78
And Tint is on my list too I need 10 k to fall from the sky right now!
#79
I just sold my offroading truck to pay my first year of insurance, I kept 400 for mods. Im having the rims painted black by a body shop for 25$ a rim. Im tinting the windows, interior led's, maybe if there is anything left ill fill in the ACURA letters on the front bumpers black. Ill keep everyone posted!
#80
Paint those rims yourself and save the $$$.
LEDS...ok
Tinted windows...got mine done for $175
Acura dome decal...$28 from here: http://www.automotiveconcepts.net/st...&type3_select=
That may leave you enough for a 3X3 tranny fluid, oil and brake fluid change. May want to look into purchasing the 3rd & 4th gear sensors, too. (abt $70)
LEDS...ok
