Foot Well Lighting
Old Oct 28, 2009 | 01:34 PM
Crestwood1001's Avatar
Foot Well Lighting
Hey guys, I really wanna pick up some blue LED strips from an auto parts store and put them in the footwells in my 06 TL, how would I go about wiring this? I dont want it to be a ricey look just a nice blue glow to go along with the rest of the blue. I figure this will be a good first mod.
Old Oct 28, 2009 | 01:44 PM
myron's Avatar
search my young friend search. I am sure someone has done this
Old Oct 28, 2009 | 02:09 PM
Matt HKD's Avatar
I plan on doing this exact same thing during my winter break from school. I bought a controller for them too so they can be dimmed. I'll let you know how mine turns out in a few months lol.
Old Oct 28, 2009 | 02:14 PM
JTS97Z28's Avatar
Humm dont your factory ones work good enough? I had an 07 base TL and the footwells had a nice dim blue hue to them. I now have a 07 Type S and the foot wells glow red. Looks bad ass!!!
Edit: Ok maybe the older models dont have them. Well if thats the case for sure do it!! They come OEM on the 07 and 08's and look amazing! DONT over do it though too bright and it looks rice (just like you said).
James
Old Oct 28, 2009 | 02:47 PM
dwb993's Avatar
I did this on my 06 base. I got the LED strips from v-leds.com and a switch from Oznium.com.
Basically, you place the lights and run your wires to wherever you want the switch. Attach all of your + to the + on the switch, run all of your - (including the one on the switch) to ground. Get an Add-A-Fuse and tap the parking lights fuse from the fusebox, throw in a 7.5A fuse and run it to the switched power lead on the switch.
I always keep the the switch in the ON position. With this setup, the lights will come on with your parking lights and will light up whenever you unlock/open your doors (I keep my headlight switch in the parking light position all the time). You can turn them off via the switch whenever you don't want them.
Note that you will want Strutking or Ultimate Pedals once you do this mod---the mods just keep snowballing! UGH!!!
Old Oct 28, 2009 | 02:56 PM
NAiL05's Avatar
My friend used CFL's in his GS300 and the interior footwell lights up pretty bright. Works better than the LED bars at the parts store just my opinion. They also come in diff colors too.
Old Oct 28, 2009 | 10:34 PM
I might order them online, I love yours DWB, thats exactly what I want, where did you ground it? Can you provide links to the parts u used? THANKS!!
Old Oct 28, 2009 | 11:50 PM
morphguy12's Avatar
I did this with the V-leds strips... had to tape up all but one of the LEDs cause it was just too bright.
Tap both of them into the center console light, they will come on whenever you turn your lights on, no need to go to the fuse box
Old Oct 29, 2009 | 12:01 AM
t3hanarchist's Avatar
can yopu clerify this a little? which power sourcE?
Old Oct 29, 2009 | 12:14 AM
KB1Spec's Avatar
here is my UA6
KB1
Old Oct 29, 2009 | 01:25 AM
morphguy12's Avatar
the light in the center console goes on when you turn on your headlights, so just tap into that as your power source.
(it's under your cup holders)
there are several threads on removing your center console
Old Oct 29, 2009 | 07:21 AM
It would be a pain to go through all that, I would tap into the parking light fuse just like he said, I def plan on doing this asap, what kind of controller do I need to dim them?
Old Oct 29, 2009 | 08:58 AM
maddsiick's Avatar
Mistuh DRiiVA
i did the footwell lighting just like dwb993 did, it looks amazing at night and its not ricey or overkill at all. I like the dimmed look on the 07 and 08s alot but this way it stands out a little bit more IMO.
Old Oct 29, 2009 | 09:08 AM
dwb993's Avatar
I needed to find a ground for my Accord fog switch and found a star ground behind the lower dash cover. I used this factory ground point for my footwell LEDs, too.
Link to the strip lights on V-LEDs.com (I used the 6" strips in blue):
http://www.v-leds.com/Strip-Lights-LED/c244685-1-3/
Use coupon code ACURAZINE for 15% off your order
Old Oct 29, 2009 | 10:24 AM
Can one of you get me a link to a controller for it? Im having trouble finding one.
Old Oct 29, 2009 | 10:29 AM
dwb993's Avatar
Try here:
http://www.oznium.com/led-controllers
Old Oct 29, 2009 | 10:35 AM
TLin401's Avatar
'13 Hyundai Sonata
I got my LED strips from here:
http://cgi.ebay.com/ws/eBayISAPI.dll...=STRK:MEWNX:IT
I put them in other people's cars as well and they love them. They are really bright too.
This vendor has them in bigger sizes with more LEDs and different colors as well.
Old Oct 29, 2009 | 10:46 AM
DWB i got that far but I dont know what one i need? I am new to this stuff, the footwell lights will be my first mod.
Old Oct 29, 2009 | 12:17 PM
myron's Avatar
did someone connect them so they work just like the dome light?
when the door opens they light up and then fade and turn off when the door closes. But that you also have an option of just turning them on with a switch. so they stay lit. This is the only way I would do this mod if I could do them just like that.
Old Oct 29, 2009 | 12:30 PM
I think they were saying if you tap into the parking light fuse with an add-a-fuse they will do that, not sure though, def wanna do this, can one of you guys that have done it please show me which controller to get exactly? And a set of directions would be sweet! Already have the add a fuse
Old Oct 29, 2009 | 12:37 PM
dwb993's Avatar
Crestwood1001: Not sure---I did not use a controller on mine, just a switch. Try PM'ing Matt HKD for more info.
myron: To have it work with the dome lights, you would have to make your wiretaps in the same locations as for the Illuminated Door sills, I think. There is a DIY thread for those here:
http://www.sbadesign.com/acurazine/sills/
There may also be some good info from bzyrice's installation of exterior puddle lights. Start at post #26 of this thread for more info:
https://acurazine.com/forums/3g-tl-photograph-gallery-96/bzyrices-progress-thread-updates-page-15-3-13-13-a-715481/
Old Oct 29, 2009 | 02:29 PM
Ohhhh i was under the impression a controller was needed, hey btw where is shrewsbury at in PA? Im in mountaintop, up in the northeast. Im gonna show my dad all this stuff when he gets home and see if he will order the stuff for me, 5 bucks a strip makes it a very affordable first mod! Considering he just bought me a 25,000$ car and paid in cash its iffy if he will let me right now lol
Old Oct 29, 2009 | 02:49 PM
dwb993's Avatar
^^Baby steps, dude. You have plenty of time to mod. Right now, get to know the car and practice your driving skills. Don't do anything stupid---as much as you love the car, you would be hating life without it.
I'm in south-central PA, below York.
Old Oct 29, 2009 | 03:05 PM
maddsiick's Avatar
Mistuh DRiiVA
https://acurazine.com/forums/showthread.php?t=715481
In this DIY...the door sill lights are tapping into a wire in the B pillar which is basically the trigger for when the door opens correct? so if we were to install the footwell LEDs and use this as the power source they would come on and fade out with the dome lights right? Can anyone confirm this for me? Thanks
Old Oct 29, 2009 | 03:17 PM
Oh i know, im about to turn 18 lol im not a new driver, and i know im not experienced, just sayin im not a new driver lol. I hate how i have a list of mods i wanna do already haha , CAI, lights, prob having the rims painted flat black soon.
Old Oct 29, 2009 | 03:19 PM
Hey dwb can u post a pic or two of the back of your car debadged? Iv got the gold emblems and i wanna take them all off the back except for the acura emblem, plus its a free mod. How did you do it? Heat and tooth floss?
Old Oct 29, 2009 | 03:20 PM
dwb993's Avatar
Not sure if they would fade, since these wires are only the door open indicators. This is why I posted the other link to the puddle lights. The puddle light tap locations WILL make them fade, but they are harder to get to. I guess it just depends on how much hassle you want to go through.
Honestly, I think the fade would look cool, but I like the way I have mine (always on, until I hit the switch).
Old Oct 29, 2009 | 03:25 PM
Yea i want them on whenever its dark, which happens with tapping into the light fuse, and the option to turn them off with the switch is nice. Where did you mount the switch? I dont wanna drill, i want it hidden
Old Oct 29, 2009 | 03:27 PM
dwb993's Avatar
Free mods rock:
De-badge--heat and floss + Goo-Gone
Remove pinstripes
5AT short shifter
Cheap mods (under $100):
Painting grill/wheels
LEDs (interior and exterior)
KP Window RollUp (my personal favorite)
Search the 3G Garage here: https://acurazine.com/forums/3g-tl-2004-2008-93/3g-tl-service-department-aka-garage-questions-answers-check-here-first-553557/
There is a TON of info to browse there.
You may think you're not a new driver, but I can tell you it takes an average of 10 years before you will see and experience enough on the road to qualify you as a "seasoned" driver. Either way, the car is new for you---learn it well and it will serve you well.
Old Oct 29, 2009 | 03:30 PM
dwb993's Avatar
I haven't mounted it yet---still not sure where I want it! Right now, I have it near my right knee, up behind the console panel. I think I will either mount it there or in the center console. Its not something I need easy access to, so I think the console is the ticket.
Old Oct 29, 2009 | 03:41 PM
ajs800's Avatar
has anyone done the puddle leds wired with the dome lights. I'm not interested in always having them lit when the parking lights are on...just when entering/exiting and when using the dome light.
In short, I'm looking for the best place to tap an oem dome/door light wire.
Old Oct 29, 2009 | 03:44 PM
dwb993's Avatar
Check bzyrice's thread I mentioned in post #21 above. Everything you need to know about the puddle lights.
Old Oct 29, 2009 | 05:25 PM
I agree with the switch, and thanks for all your help here! Im learning alot about my car. And I know I lack experience lol im not denying it, id like to think im a better driver than some of the morons I know, some people have to fly around all the time, not good for your car or your health ya know?
Old Oct 29, 2009 | 06:16 PM
maddsiick's Avatar
Mistuh DRiiVA
yea i have mine wired the same way, with a switch...i just wanted to know if this was a possiblity with the wires in the b pillar since i want to do the puddle lights but i dont want to go into the headlinner. i guess this is the only way to go
Old Oct 29, 2009 | 08:04 PM
Dude you can wire it to any light you want if your willing to rip apart your interior haha, you could have them come on with the vanity lights if ya wanted to get crazy
Old Oct 30, 2009 | 10:32 PM
So where did you hide the wiring? Im gonna order these soon, my project right now is claybaring the car tomorrow
Old Oct 31, 2009 | 01:46 AM
Pz_'s Avatar
Pz_
I think to get this you'd need to get into the A pillar, which is what has prevented me from doing it so far. I'd like to find something a little easier to get to personally.
Old Oct 31, 2009 | 01:19 PM
Im not gonna wire mine to the dome lights thats to much work and I dont wanna rip up my interior, im gonna use an add a fuse and tap into the parking light fuse just like he said.
Old Oct 31, 2009 | 01:54 PM
dwb993's Avatar
Use the rear dome lights for your tap. Run the line under the headliner and down to the floor. Run all 4 footwell strips to that main tap and ground. They will function just like the domes and will fade out after you close the door. They will also turn on when you turn on the rear domes either via the rear dome switch itself or the master switch on the front upper console. No switch is needed and if you use speaker gauge wire, you should not need a fuse. One more hint: use quick disconnects on the strips for easier replacement, if necessary.
Old Oct 31, 2009 | 02:00 PM
So DBW here is my plan, just wanna triple check before I start. Iv got a red nos switch that used to be used for my KC Daylighters on my truck. Ill tap into the parking light fuse, run all my wiring, find a good ground bolt, and whenever my lights are on the footwells will light up. Correct?
