fog lights
Read, There are a ton of writeups about this. you cant just "tap" into them or you will blow fuses. you can take the bulb out and just run the wire to the lower fogs then you will be fine.
06 WDP/Ebony MT NAV ASPEC
Tap into the upper ones but use a relay to the battery for power. All you will be doing is powering the relay off the oem cct and that is pretty much negligible. If however you want them to turn on separately then you need to run to a new switch in the cabin.
InFaMouSLink
10-27-2015 06:51 PM
sockr1
10-01-2015 01:31 AM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
