F-167: Heater/Water/Coolant Control Valve DIY
#41
Here's the diagnostic on the air mix controller for the Driver's side. The steering column dash cover is just held on by a bunch of clips. You can shim it open or apply steady pressure and they'll pop. Let us know if you figure it out.
#42
I'd suspect you buggered installation of the cable. The air mix works like a see-saw with coolant valve and damper on the inside of the cabin.
Get back in there, give this scan a shot, unplug your battery for 30 minutes (this should reset the code), and let us know how you make out.
#43
I ordered the parts, but I have a question now that I have the parts in front of me. The cable part number I ordered is 79544-SDA-A10, however, the cable is black and has different ends compared to wire end on the blue cable in the car now. Did they upgrade the cable? Did I order the incorrect part?
Dan,
Gonna shoot you a pm.
Dan,
#44
Fearless DIY Guy
The ends should be wire-wound...the sleeving, crimp-end, and general construction are the same, but this is not consistent with the OE component.
I don't know if the part was revised by Honda, but this is not the OE component.
#45
That is the right cable but for a 6MT. I'm not sure if it's much different than the 5AT. Years 06-08 also have a different P/N.
#47
No worries, I'm not sure why they used the AT cable in your car, probably mixed up during assembly, but that is indeed the right cable. I'm guessing the only difference is the connector. Why are you replacing the cable?
#51
If I knew for certain that the application of the 5AT valve cable was not in spec to meet the 6MT needs, which it definitely looks like, I'd have Acura fix it on their dime.
#53
Just finished installing the valve and changed hoses. What a pain in the ass!
It has to be the cable. I manually opened the valve without the cable on an heat came through.
I used to get service at metro Acura, including mine. If I recall, there may have been two 6Mt cars getting service there and I did get my heat valve changed before when I wasn't getting heat a few years ago.
#54
Sounds like the culprit. They probably replaced the cable with the wrong one.
#55
Helped me with the install in my 7th gen accors 6-6.. but my strut bar is a big p.I.t.a compared to that of the TL. Also I flushed my heater core since it was just one more hose to disconnect.
Now I have heat!!!
Now I have heat!!!
#56
Hey guys, sorry for the bump, but I'm suffering the same issue as last year. I haven't changed anything yet on the car, and I do have heat, it's just not hot enough. I have the heater set to 82F / 28C full blast most of the time during a 45 minute drive and I don't feel hot. On my 94 accord if I blasted max heat I wouldn't be able to take it within 15 minutes.
All vents seem to be roughly the same temperature. The problem is that the air is not hot enough. Coolant is topped off. Car temp is constantantly above 4 small ticks on the temp gauge, which I am sure is fine. Any ideas? Thanks.
#57
Fearless DIY Guy
1.) Replace the valve body
2.) Replace the cable
3.) Calibrate
#59
This is the cheapest I could find it:
http://www.ebay.com/itm/Honda-Water-...-/200456846023
Should work just fine right? I wanted to double check before I ordered it. I also cannot tell if it is OEM or not.
#60
OP Thanks for the great write-up, I just did this last night with ease thanks to this. I had one question tho, should the silver crimped end of the cable be in the clamp on the bracket, or how it is shown in the original pictures of this thread?
That's how mine was before I started and I left it like that and well, no heat still. I'm going to go out and mess with it again today. Any help would be great. Thanks
BTW It's an '07 Type S Automatic.
#61
I calibrated the cable to the heater control valve and know it's working as it should with the Hi (open) Lo (closed) settings and I still have no heat. I've worked the thermostat as others have from Lo to Hi and allowed the car run up to temperature twice with no change. I've also checked all fuses. Any one else have any other ideas before I need to take it to the stealership? Bad heater core?
#62
In my case I needed "Step 9: Drive car around for 5 min so the coolant can circulate!"
I left my house earlier after double checking everything and a few miles down the road the Heat came on! Guess the coolant hadn't fully circulated with me running it up to operating temps twice in the driveway. Go figure! Now I'll enjoy defrosting my car in the mornings Thanks again for this thread. Easy to do, Yes. Easy to figure out, Not with out this thread.
#63
I know this is old, but people may still be looking at this. If you've determined it's your cable that's bad and the valve is still good, my suggestion is to save yourself the headache and just unhook the cable from the valve, and manually set it to the open position. Honda eliminated these parts starting with the 4th gen TL/8th gen Accord. The mix doors are what controls the level of heat, so having coolant always flow through the core is fine.
Both my cable and valve are fine, I had issues with the driver side mix motor, but checked these as a starting point. Since I was already in there I just disconnected the cable. One less failure point is fine by me. There are no negative effects.
#64
Yeah, it's a poor design feature.. Good to know it's just a passthrough on later designs.
#65
It sure is. It's double bad that the driver side mix motor also controls this valve (via a 'see saw' like gear design). So if the cable/valve is stuck it'll prevent the driver blend door from opening as well. Not sure what the chances of the cable going bad are though, my '06 with 79k miles was perfectly fine. I manually moved the cable/valve and it was smooth, but I'd rather bypass the whole valve system and be done with it.
#66
#67
Fearless DIY Guy
I'm having heating issue now whereby I have to increase the temp to max before any heat can produce. But once I lower it, the heat seems to stop coming out. Do you think this is due to the cable? Also, how do you manually set and keep the valve open when the cable is unhooked? I'd like to try this method before having a mechanic check it out. Thanks!
Easiest fix is to start by replacing the valve and the cable, which is pretty cheap and relatively easy to do. Make sure you follow the service manual and the attachment studs for the valve and mixer are in the proper position before attaching. This has worked for a good number of members.
#68
DM
#69
Take a look at the first post/pics in this thread. Once you find the valve on your car you'll see how to manually open/close the valve. 12:00 position = closed. 9:00 = open
#71
How much is it there? This shit place down the road is $1400 / mo, 2nd kid is only 5% off.
#72
Fearless DIY Guy
I'll likely do the same once the time comes. Although many years away, it's a toss-up between the TLX and two other vehicles, both of which have comparatively slow forums and will go unnamed until the time grows nigh.
Child #1: 3-years old, fully potty trained
Child #2: 17-months old
10% discount applied since S.O. is a teacher
...$1782 a month. I can't complain, though. The program and its staff are genuinely caring educators that are serving well for my children's education.
to us when these days are done and to some at least diluted fixed costs!
#73
That time of year I guess.. ttt
#76
Are there any signs that the heater control valve has failed? I'd hate to replace it, only to find out it's something else.
Will the valve not turn or engage, or will there be coolant leaking around the valve??
My heater just doesn't work at all. Whether it's stationary or in drive, there's no warm air coming out at all. Unlike OP, it doesn't come on even after car is fully warmed up.
#77
#78
Question
I have made this DIY this week because I had a coolant leaking from this part. However, I noticed that the switch(and the wire controlling it) is in the middle positions between open and close (not fully opened or fully closed) and it never moves whatsoever. It doesn't move when I turn on the car in the morning or turn it off or after driving the car for a while. Has anyone who performed this replacement noticed something like that?
#79
Well, after 15.5 years and ~311K miles, my HCV finally turned into a geyser. The internal plastic part of the rotating valve had totally "melted" away and coolant was leaking out of the front of the valve where the shaft is.
I found it easier to first unbolt the bracket from the firewall (use a swivel on the end of a long extension, 10mm). This gives you a fair amount of play to access the spring clamps on either side. I pulled both hoses off and then removed the bracket and valve in one piece. I found my 16" curved needle nose pliers invaluable in this task.
Thanks to Majofo for this DIY!!
Edit: Bought the new valve from Amazon for ~$15 shipped. I wouldn't be afraid of the lousy rating. Looks like a couple of Honda dumbasses bought the wrong part and choose to give negative reviews for their dumbassness:
#80
That's pretty good mileage before yours failed!
