Excelerate Performance: XLR8 Brake Packages for AcuraZine!!
Excelerate Performance has spent an extensive period of time working with Acurazine members and Acura vehicles on their XLR8 brake packages. We’ve tested, installed and used on our very own vehicles the brake components in these very packages.
These Acurazine brake packages are designed to improve braking performance and durability at a reasonable price. The packages in a nutshell include STOPTECH performance rotors, which are offered in premium blank, slotted, drilled, or drilled and slotted, and STOPTECH Performance pads. All of the rotors have a black e-coating on the hubs and vanes and an advanced alloy composition. The STOPTECH slotted rotors for the front of some Acuras are also a Curved Vane Power Alloy Disc, which helps reduce heat in the brake system and utilizes more durable alloys. The STOPTECH Performance pads are a para-aramid compound, which has great initial bite and long-term performance and lower dust and noise than most aftermarket brake pads.
We have a multitude of different packages available for the Acurazine community. Each package comes with front and rear STOPTECH rotors and STOPTECH Street Performance Pads. We also now offer packages with our XLR8 Stainless Steel Brake Lines included.
Slotted Rotors:
Drilled and Slotted Rotors:
Premium Blank Rotors:
The Stoptech Street Performance Brake Pads that come with these packages are a para-aramid compound, which has great initial bite and long-term performance and lower dust and noise than most aftermarket brake pads. Their Maximum Operating Temperature (MOT) is 1300°F which is higher than any other street pad currently on the market. Not only do they perform well in hot temperatures they also perform well in cold temperatures. We have plenty of customers who run these pads in sub-zero climates and have no problems.
Our XLR8 Stainless Steel Brake Lines are made up of teflon hose that has an extruded teflon core with an outer stainless steel braided wire covering. The ends are then permanently crimped on each end. Each line is then finished with a black PVC cover, which gives added protection from flying debris or further abrasion protection from the line rubbing on suspension components. All lines are DOT certified and manufactured for us by an industry expert who has 25 years of experience.
For your convenience, here is a list of every package we offer and the links to our webstore for those packages:
CL: 2001-2003
Drilled & Slotted - $425 plus shipping
http://store.excelerateperformance.c.../i-398969.aspx
Drilled & Slotted w/ XLR8 SS Brake Lines - $515 plus shipping
http://store.excelerateperformance.c...i-1890137.aspx
Slotted - $375 plus shipping
http://store.excelerateperformance.c.../i-398968.aspx
Slotted w/ XLR8 SS Brake Lines - $465 plus shipping
http://store.excelerateperformance.c...i-1890177.aspx
Premium Blank - $279 plus shipping
http://store.excelerateperformance.c...i-1760991.aspx
Premium Blank w/ XLR8 SS Brake Lines - $369 plus shipping
http://store.excelerateperformance.c...i-1890147.aspx
RDX: 2007-2009
Drilled & Slotted - $385 plus shipping
http://store.excelerateperformance.c.../i-541594.aspx
Drilled & Slotted w/ XLR8 SS Brake Lines - $475 plus shipping
http://store.excelerateperformance.c...i-1890141.aspx
Slotted - $365 plus shipping
http://store.excelerateperformance.c.../i-541593.aspx
Slotted w/ XLR8 SS Brake Lines - $455 plus shipping
http://store.excelerateperformance.c...i-1890181.aspx
Premium Blank - $255 plus shipping
http://store.excelerateperformance.c...i-1761007.aspx
Premium Blank w/ XLR8 SS Brake Lines - $345 plus shipping
http://store.excelerateperformance.c...i-1890151.aspx
RDX: 2010-2012
Drilled & Slotted - $390 plus shipping
http://store.excelerateperformance.c...i-1760989.aspx
Drilled & Slotted w/ XLR8 SS Brake Lines - $480 plus shipping
http://store.excelerateperformance.c...i-1890144.aspx
http://store.excelerateperformance.c...i-1760985.aspx
http://store.excelerateperformance.c...i-1890185.aspx
Premium Blank - $259.99 plus shipping
http://store.excelerateperformance.c...i-1761083.aspx
Premium Blank w/ XLR8 SS Brake Lines - $349.99 plus shipping
http://store.excelerateperformance.c...i-1890174.aspx
RSX Base: 2002-2006
Drilled & Slotted - $407.99 plus shipping
http://store.excelerateperformance.c...i-1891168.aspx
Drilled & Slotted w/ XLR8 SS Brake Lines - $497.99 plus shipping
http://store.excelerateperformance.c...i-1891173.aspx
Slotted - $375.99 plus shipping
http://store.excelerateperformance.c...i-1891169.aspx
Slotted w/ XLR8 SS Brake Lines - $465.99 plus shipping
http://store.excelerateperformance.c...i-1891171.aspx
Premium Blank - $224.99 plus shipping
http://store.excelerateperformance.c...i-1891170.aspx
Premium Blank w/ XLR8 SS Brake Lines - $314.99 plus shipping
http://store.excelerateperformance.c...i-1891174.aspx
RSX Type S: 2002-2006
Drilled & Slotted - $439.99 plus shipping
http://store.excelerateperformance.c...i-1891125.aspx
Drilled & Slotted w/ XLR8 SS Brake Lines - $529.99 plus shipping
http://store.excelerateperformance.c...i-1891130.aspx
Slotted - $409.99 plus shipping
http://store.excelerateperformance.c...i-1891123.aspx
Slotted w/ XLR8 SS Brake Lines - $499.99 plus shipping
http://store.excelerateperformance.c...i-1891124.aspx
Premium Blank - $239.99 plus shipping
http://store.excelerateperformance.c...i-1891132.aspx
Premium Blank w/ XLR8 SS Brake Lines - $329.99 plus shipping
http://store.excelerateperformance.c...i-1891134.aspx
TL: 1999-2003
Drilled & Slotted - $410 plus shipping
http://store.excelerateperformance.c.../i-398967.aspx
Drilled & Slotted w/ XLR8 SS Brake Lines - $500 plus shipping
http://store.excelerateperformance.c...i-1890146.aspx
Slotted - $360 plus shipping
http://store.excelerateperformance.c.../i-398965.aspx
Slotted w/ XLR8 SS Brake Lines - $450 plus shipping
http://store.excelerateperformance.c...i-1890188.aspx
Premium Blank - $265 plus shipping
http://store.excelerateperformance.c...i-1761516.aspx
Premium Blank w/ XLR8 SS Brake Lines - $355 plus shipping
http://store.excelerateperformance.c...i-1890176.aspx
TL Base: 2004-2008
Drilled & Slotted - $450 plus shipping
http://store.excelerateperformance.c.../i-338785.aspx
Drilled & Slotted w/ XLR8 SS Brake Lines - $540 plus shipping
http://store.excelerateperformance.c...i-1890138.aspx
Slotted - $405 plus shipping
http://store.excelerateperformance.c.../i-304785.aspx
Slotted w/ XLR8 SS Brake Lines - $495 plus shipping
http://store.excelerateperformance.c...i-1890178.aspx
Premium Blank - $281.99 plus shipping
http://store.excelerateperformance.c...i-1760993.aspx
Premium Blank w/ XLR8 SS Brake Lines - $371.99 plus shipping
http://store.excelerateperformance.c...i-1890148.aspx
TL Manual & Type S: 2004-2008
Drilled & Slotted - $470 plus shipping
http://store.excelerateperformance.c.../i-338784.aspx
Drilled & Slotted w/ XLR8 SS Brake Lines - $560 plus shipping
http://store.excelerateperformance.c...i-1890139.aspx
Slotted - $435 plus shipping
http://store.excelerateperformance.c.../i-304786.aspx
Slotted w/ XLR8 SS Brake Lines - $525 plus shipping
http://store.excelerateperformance.c...i-1890179.aspx
Premium Blank - $315 plus shipping
http://store.excelerateperformance.c...i-1760994.aspx
Premium Blank w/ XLR8 SS Brake Lines - $405 plus shipping
http://store.excelerateperformance.c...i-1890149.aspx
TL: 2009-2013
http://store.excelerateperformance.c.../i-466577.aspx
http://store.excelerateperformance.c...i-1890143.aspx
http://store.excelerateperformance.c.../i-466576.aspx
http://store.excelerateperformance.c...i-1890183.aspx
Premium Blank - $299.99 plus shipping
http://store.excelerateperformance.c...i-1761082.aspx
Premium Blank w/ XLR8 SS Brake Lines - $389.99 plus shipping
http://store.excelerateperformance.c...i-1890167.aspx
TSX: 2004-2008
http://store.excelerateperformance.c.../i-401963.aspx
http://store.excelerateperformance.c...i-1890140.aspx
http://store.excelerateperformance.c.../i-401954.aspx
http://store.excelerateperformance.c...i-1890180.aspx
http://store.excelerateperformance.c...i-1761005.aspx
http://store.excelerateperformance.c...i-1890150.aspx
TSX: 2009-2010
Drilled & Slotted - $420 plus shipping
http://store.excelerateperformance.c.../i-466579.aspx
Drilled & Slotted w/ XLR8 SS Brake Lines - $510 plus shipping
http://store.excelerateperformance.c...i-1890142.aspx
Slotted - $350 plus shipping
http://store.excelerateperformance.c.../i-466578.aspx
Slotted w/ XLR8 SS Brake Lines - $440 plus shipping
http://store.excelerateperformance.c...i-1890182.aspx
http://store.excelerateperformance.c...i-1761081.aspx
http://store.excelerateperformance.c...i-1890152.aspx
TSX: 2011-2012
Drilled & Slotted - $400 plus shipping
http://store.excelerateperformance.c...i-1676247.aspx
Drilled & Slotted w/ XLR8 SS Brake Lines - $490 plus shipping
http://store.excelerateperformance.c...i-1890145.aspx
Slotted - $335 plus shipping
http://store.excelerateperformance.c...i-1676248.aspx
Slotted w/ XLR8 SS Brake Lines - $425 plus shipping
http://store.excelerateperformance.c...i-1890187.aspx
Premium Blank - $245 plus shipping
http://store.excelerateperformance.c...i-1761084.aspx
Premium Blank w/ XLR8 SS Brake Lines - $335 plus shipping
http://store.excelerateperformance.c...i-1890175.aspx
To order, please just click on one of the links that I have provided and proceed to checkout with a CC or with Paypal. To obtain a shipping quote, simply click the package you want for your car, add the part to cart and enter your zip code into the shipping calculator. If you'd like to check stock you can shoot me a PM and I'll gladly let you know if something is or isn't available. Most of these packages are in stock and ready to ship same day.
The following 3 users liked this post by Excelerate:
You may want to mention your 13" BBK too. I think I posted the actual stopping distances compared to stock and to the Rotors BBK somewhere on here. The numbers speak for themselves.
Received 3,824 Likes
+1 for this package! I love them!
Pads dust quite a bit though.
New brake packages added for other Acura models.
Slotted Rotors:
CL: 2001-2003
MDX: 2007-2013
Drilled & Slotted - $467.99 plus shipping
http://store.excelerateperformance.c...i-1891356.aspx
Slotted - $436.99 plus shipping
http://store.excelerateperformance.c...i-1891357.aspx
Premium Blank - $314.99 plus shipping
http://store.excelerateperformance.c...i-1891355.aspx
NSX: 1991-1996
Drilled & Slotted - $538.99 plus shipping
http://store.excelerateperformance.c...i-1891383.aspx
Drilled & Slotted w/ XLR8 SS Brake Lines - $628.99 plus shipping
http://store.excelerateperformance.c...i-1892771.aspx
Slotted - $507.99 plus shipping
http://store.excelerateperformance.c...i-1891384.aspx
Slotted w/ XLR8 SS Brake Lines - $597.99 plus shipping
http://store.excelerateperformance.c...i-1892770.aspx
Premium Blank - $354.99 plus shipping
http://store.excelerateperformance.c...i-1891385.aspx
Premium Blank w/ XLR8 SS Brake Lines - $444.99 plus shipping
http://store.excelerateperformance.c...i-1891386.aspx
NSX: 1997-2005 NSX
Slotted - $839.99 plus shipping
http://store.excelerateperformance.c...i-1892774.aspx
Slotted w/ XLR8 SS Brake Lines - $929.99 plus shipping
http://store.excelerateperformance.c...i-1892775.aspx
Premium Blank - $699.99 plus shipping
http://store.excelerateperformance.c...i-1892772.aspx
Premium Blank w/ XLR8 SS Brake Lines - $789.99 plus shipping
store.excelerateperformance.com/xlr8_performance/acurazine_brake_packages/brakepackagewlpb9705nsx/i-1892773.aspx
RDX: 2007-2009
RDX: 2010-2012
RL: 2006-2012
http://store.excelerateperformance.c...i-1891369.aspx
http://store.excelerateperformance.c...i-1891370.aspx
Premium Blank - $286.99 plus shipping
http://store.excelerateperformance.c...i-1891371.aspx
RSX Base: 2002-2006
TL: 1999-2003
TL Base: 2004-2008
TL: 2009-2013
TSX: 2004-2008
TSX: 2009-2010
TSX: 2011-2012
ZDX: 2010-2012
Slotted Rotors:
CL: 2001-2003
MDX: 2007-2013
NSX: 1991-1996
NSX: 1997-2005 NSX
RDX: 2007-2009
RDX: 2010-2012
RL: 2006-2012
RSX Base: 2002-2006
TL: 1999-2003
TL Base: 2004-2008
TL: 2009-2013
TSX: 2004-2008
TSX: 2009-2010
TSX: 2011-2012
ZDX: 2010-2012
do you happen to know if the rotor setups for the Type S are lighter than stock and if so by how much? I havn't seen this data anywhere and i was just curious, ill be in the market for new brakes come spring/summer so i will likely be stopping into XLR8 to get one of these packages installed plus some other goodies. Warm weather can't come soon enough!
I'm heavily considering going with one of these brake packages in the future (OE rear rotors warped), especially since you've given me such great customer service in the past.
I'm also considering getting the SS brake lines when I do, but am wondering about them since I've never considered maintaining my braking system until I've had to do some emergency stops on the highway and drag strip in the last few years. A quick search tells me that SS brake lines can last less than conventional lines, but it seems that yours have an external PVC tubing that prevents failure that plague regular SS lines. Does that mean that these offer all the pros of going SS over OE without any drawbacks?
XLR8 Performance now offers our very own XLR8 Stainless Steel Brake Lines. Each stainless steel brake line is made up of teflon hose that has an extruded teflon core with an outer stainless steel braided wire covering. The ends are then permanently crimped on each end. Each line is then finished with a black PVC cover, which gives added protection from flying debris or further abrasion protection from the line rubbing on suspension components. All lines are DOT certified and manufactured for us by an industry expert who has 25 years of experience.
The advantage of stainless steel brake lines is in the reduction of volumetric expansion from heat. Over time and under continuous use, the stock rubber lines can swell and expand, resulting in a mushy pedal or brake fade. The rubber cover is also susceptible to deterioration and failure. Stainless steel lines help prevent this expansion and keep your pedal firm and can protect from the flying debris your brake lines may be exposed to.
Former Sponsor
XLR8 Brake Packages in stock and ready to ship!!
Former Sponsor
PM us for a quote on our XLR8 brake packages by Stoptech!
Former Sponsor
We have brake packages in stock and ready to ship!
Former Sponsor
Thank you Acurazine for your continued support! We're continuing to sell these great packages!!
Former Sponsor
These packages are a great deal! PM for a quote!
Former Sponsor
Brake packages are in stock and ready to ship!
Former Sponsor
Former Sponsor
We have these brake packages in stock and ready to ship!
Former Sponsor
PM me for an XLR8 brake package quote!
Former Sponsor
