Engine noise
Dr. Feelgood
Engine noise
I hope this is not a repost, but I've recently noticed a small ticking sound from the engine. It's the sound that those big trucks makewhen you park next to them, you know - tick, tick, tick ,tick. I was wondering if this is normal. My TL only has 5K on her. Thanks
Team Anthracite Webmaster
i think i know what you mean... it's when engine is idling right? more noticable if you open the hood? almost sounds kinda abnormal, but i'm not sure what it is. anyone else getting this?
Dr. Feelgood
The ticking sound I'm talking about sounds like the sound from a desil truck or something to that effect. I've only noticed it now and not during the winter. The sound is more prominent through the driver's side.
Valve Lifter noise? Dunno
Some people have had the ticking noise go away (on other cars) by switching oils. Try pouring some Havoline 5w-30 SM/GF-4 in there. It might help, it wouldn't hurt.
Michael
Michael
Check this link. It may explain what's causing that ticking sound http://autorepair.about.com/cs/troub...a011902a_4.htm
Dr. Feelgood
Dr. Feelgood
Michael
Michael
It should be to early, but that can happen with worn bearings on your belt driven accesories. THe ticking is characteristic of desal trucks. I am not positive what causes it though. Either way, it is not the same reason for your TL, cause thats obviously not diesel. Get it checked out, better safe the sorry.
i also say it's most likely valve lifters, if it's a soft and constant ticking sound... which is unusual on a new car. i'd call the dealership in advance and reserve a loaner... it'll take at least a few hours to fix.
04 A-TL 6MT SSM/E N/Navi
Originally Posted by ndx2
i can record it, but i'd need someone to host it for me. any volunteers?
I think it's solenoids from fuel ingectors.
Dr. Feelgood
Originally Posted by DEG
Probably only injecter noise.
Dr. Feelgood
Originally Posted by jhan1102
but most of these posters claim that the noise goes away after the engine is warmed up. Mine still ticks after 10 to 15 minutes. I think I'll have to insist that the dealer adjust the valves like some have suggested.
Originally Posted by 05TLTony
I asked the service manager and he says this was the reason. However, I did not recall hearing this a couple of months ago.
print out the TSB for noisy engine, it plainly states that the tappets need adjusting.
From my experience... "Tick tick tick" That sound is normal. I took the car in to the dealer and did side by side test. When I first got this car I was freaking out cuz of the engine noise. It was alot different than my other Honda V6 engine sound. It just takes time getting use to.
Think of it as if you are dating a new girl. They all nag differently.
Just take the car to the dealer, and have them give you a print out as a proof that you came into the shop with engine problem. If something happens down the road... you can have them fix it beyond your 48 month?
Good luck!
Good luck!
INTERESTING REPLY ON THE "tick tick tick" that is what my post was a few messages down . . . i describe it as a purr or a in motin sewing machine.. Its funny how we all analyze things after others post.. and the girlfriend reference is so true..................... i had a 99 accord coup ex v6 prior and in my opinion had a smoother ride and less vibrating engine... but i still love my TL
snorf
11-04-2019 06:44 AM
Mike Bertram
09-10-2015 09:27 AM
