EBC Red Stuff pads..
Originally Posted by LivingLarge
I have Red stuff on the front and Green stuff on the rear. The Red actually stopped making noise after 100 miles but the Green sometimes make noise under light braking.
I also had greenstuff on my wifes X-type a while back and they never made noise so i'm not too concerned. I just wanted to check..
did you apply caliper grease to the backside of the pads- and the end tabs where they fit into the slider clips- you cleaned and lubed the sliders ?
What pad bedding method are you using
It can take a few hundred miles for some performance pads- or more - to get fully bedded
They also need a certain min temp to work well.
3 coats of synthetic car wax on the rim surfaces will cut down brake dust sticking to the rim
Rust ridge on rotors will cause noises too.
ExcelerateRep
10-14-2015 08:20 AM
