Dual Mass Flywheel
Dual Mass Flywheel
Is anyone familiar with the dual-mass flywheel that's used on the '04 TL 6MT? Can anyone describe it, the theory behind it and if its been used before or if its an Acura first?
i have a legend 6spd dualmass fly wheel. all i know is that they cost 1k to replace, and u can't remachine them or u will get major chatter. be prepared to fork over 1k+ to change ur clutch at 100k
I did a search on google for dual mass flywheels and found out some interesting information.
Apparently DMFWs began life in diesels to smooth out their the harmonics from their power stroke.
The reason they're used is:
Eliminate excessive transmission gear rattle, making driving comfortable at any speed; Reduce shift effort; Increase fuel economy.
The downside is as was previously stated; If you have to do a clutch the very expensive DMFW has to be replaced as well - just go easy on the clutch.
There was an interesting thread on an Audi forum about DMFW - someone had to replace theirs at an early point in the car's life.
www.luk.de has information on the design of dmfw and why they are used. According to luk many Europian cars now use dmfw to reduce vibration at low speeds in higher gears.
08_UA7_Gr33k
02-11-2016 02:17 PM
InFaMouSLink
10-30-2015 09:43 AM
AcuraKidd
09-25-2015 11:18 PM
