Driver side front end sqeauking
First off i have a 06 w/2900 miles and the only mod i did was install the a spec kit. A couple of days later i begin to noticed that when i go over bumps on the road at low speeds i get a squeaking noise from the front driver side. Once and a while i hear it, but i know it's there. Has anyone ever experienced this?
Had the same problem...
on my 06 with about 4,000 miles, took it in and they found I needed a new drivers side knuckle. I am not that educated about suspension components so I posted a thread about it a few months ago with the part numbers. If you run a search you should be able to track it down.
Good Luck!
Good Luck!
TLDude876
12-28-2016 03:18 PM
nanos
11-12-2015 08:41 PM
