Drag Racing Tips
Old Aug 1, 2012 | 03:56 PM
  #41
tpurkey's Avatar
Awesome write up! I'm going to be dragging for the first time later this month and this should help quite a bit!
Old Jan 31, 2013 | 02:39 PM
  #42
EDMGenerTL's Avatar
5th Gear
Go fast!
Old Jan 31, 2013 | 04:55 PM
  #43
BEAR-AvHistory's Avatar
Don't worry about reaction time or the car in the other lane. Concentrate on learning to launch the car. Your ET is pretty much set in the first 60ft.
Old Jun 22, 2013 | 05:54 PM
  #44
MistherHowl's Avatar
6th Gear
Originally Posted by Dave_B
I thought I'd post this because I constantly read about manual drivers mis-shifting the 2-3 and 3-4 in the 1/4 mile. There is a specific way you need to hold your hand when shifting gears. This will greatly reduce your chances of hitting gates and missing gears. This is how professional drivers shift gears.
1-2 shift
Hold the shifter pistol grip style and pull directly back. Easy enough.
2-3 shift
With your palm, place it BEHIND the shift knob. Your finger should wrap around the right side of the shift knob. Your wrist should be at a 90 degree angle. Use palm of your hand and push forward. The shifter should easily slide into 3rd.
3-4 shift
Invert your hand so that your thumb is pointing down. Wrap your hand around the front of the shift knob and pull directly back. You'll hit the 3-4 everytime.
What is the best method for shifting? Rev match?
Old Apr 22, 2014 | 02:06 PM
  #45
runutsooh's Avatar
good write up. I have always wondered how to get the best launch out of my auto. thanks
Old Jul 11, 2014 | 10:23 PM
  #46
skwidstyle2's Avatar
1999 4at
The technique:
1) Foot on brake
2) Put the tranny into neutral
3) Blip the throttle to around 4000rpms or so, foot still on brake. You should feel the pedal get a bit softer and you can push the brake down a bit more. Do not hold the gas to 4000rpms, simply rev up the engine and release the gas.
4) Once the rpms fall below 1000rpms, put tranny back into gear
5) While your foot still on the brake, mash the gas pedal fully and hold for nearly 1 second (no more) to bring up the rpms.
6) Release brake with gas fully depressed.
This is not neutral drop. The technique allows you to build more stall at launch (~200-300rpms more stall).
... does absolutely nothing on the 99 tlp i can tell you with 100% positivity, yet i do notice that every now & then when doing back road runs for whatever reason the car lets me stall up to like 2600 vs. the regular approx. 2200 ... no idea why but when it does i slightly spin to where some better traction tires im sure would hookup perfect ... again i have no way of controlling this it happens 1 out of every 15-20 launches randomly, but will then allow it to do so 3 or 4 times.
Old Mar 12, 2015 | 10:53 PM
  #47
JDMJunkie12s's Avatar
The technique:
1) Foot on brake
Does turning on or off the ASV make a difference other than grip on the tires?
Old Mar 13, 2015 | 11:47 AM
  #48
anx1300c's Avatar
VSA aggresively cuts power when your tires begin to spin even slightly. You always want it off for maximum acceleration.
Old Mar 18, 2015 | 03:59 PM
  #49
1black_seven's Avatar
Slot Machine Lubricator
That brake torquing technique is hocus pocus imo. Just launch on green and work the throttle to keep traction.
Old Mar 21, 2015 | 06:57 AM
  #50
F23A4's Avatar
Brake torquing effectiveness varies depending on make, model and year of the car.
Old Jul 5, 2019 | 10:56 PM
  #51
Acura TL Builder's Avatar
Mash it to the floor and hold on?
F-C
Motorsports News
33
Aug 22, 2018 09:53 AM
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
polish_pat
Sep 30, 2015 12:22 PM
Froid
Sep 27, 2015 06:16 PM
ivan06106
Sep 26, 2015 04:38 PM
