Dom's Video Switch HELP!?!?!?
Old Mar 17, 2008 | 11:07 PM
krmerritt's Avatar
Racquetballer
Exclamation Dom's Video Switch HELP!?!?!?
Has anyone tried making a video switch like daman's with the 2007 Accord fog light switch and harness? I just picked up the both per his part #'s but am confused on the wiring. Has anyone else tried this or know how to get a hold of daman? Any help would be greatly appreciated as this is the last step on my install. Thanks guys.
- Kyle
Old Mar 18, 2008 | 12:29 AM
krmerritt's Avatar
Racquetballer
These are his instructions, but he used the unit from AVElectronics and the wiring is a little different. Thank you for any help you can provide.
Originally Posted by daman
The terminals on the back of the switch were hard to get to and make connections to, so I bought the harness that goes with the switch; therefore I could easily connect to the wires that go to the terminals of that switch. The harness has a few different connectors on it for the fog light application...just cut those off and use the connector that fits into the switch and the wires that come from it.
I utilized the navigation interface unit from av electronics, so if you are using a different interface, your wiring to the interface would be similar, but a different color wire. Here goes:
1) Connect red wire with fuse from navi interface to grn wire of switch
2) Remove red/blk jumper
3) Connect red/blk wire (the one connected to contact in switch) to 12V (+) power ACCESS.
4) Connect blu wire to ground
5) Connect and splice red/blk wire from #2 in switch to contact #3 of VSA switch
6) Connect and splice red wire from #2 in switch to contact #4 of VSA switch
NOTE: IF YOU ARE LOOKING AT THE MALE SIDE OF THE VSA SWITCH WITH THE LOCKING TAB ON TOP, IT IS CONTACT #3 AND #4 COUNTING FROM LEFT TO RIGHT. CONTACT #3 IS POSITIVE, CONTACT #4 IS NEGATIVE
Old Mar 18, 2008 | 11:48 AM
krmerritt's Avatar
Racquetballer
bump
Old Mar 18, 2008 | 05:22 PM
krmerritt's Avatar
Racquetballer
Anyone know how to get a hold of daman? I've PM'd him twice but he hasn't been active since Dec 07.
Old Mar 20, 2008 | 05:50 PM
krmerritt's Avatar
Racquetballer
can anyone help? I've already blown one of my fuses from the "add-a-circuit" method. I'm anxious to finish the install. Thanks.
Jul 16, 2017 07:33 AM
SexyRL
4G TL Problems & Fixes
Aug 19, 2016 10:03 PM
xsilverhawkx
Sep 28, 2015 06:51 PM
eastcoastguy
Sep 23, 2015 06:29 AM
