does your rev over 5,000rpm?
i wonder if your TL rev over 5,000 rpm when its park? i just want to know. cuzz after i put my INJEN CAI in and rev the engine, i notice it won't go over 5,000 rpm. i think that is normal. after i completely installed it, i went for a test drive using sport shifter and it went red line as i ecspected. and i'm assuming the car won't go over 5,000rpm when its parking for some safter reason. i just want to double check with everyone in here.
P.S its sound loud and mean with the CAI installed. for the hp wise im not sure with it gain for that.
thanks
thanks
Its to keep idiots from revving the motor in park- thats really hard on it -
I dont care what they do on the TV car shows- they dont OWN those cars!!!
A J35A8 EG civic is in
^^ just curious, how is it really hard on the engine. If you have a link to some article Id appreciate it. I not really too good with the mechanicals of a car so thats why id like to know. Thanks
94 DC4 RS LSV/Turbo
it is obvious that excessive revs while parked is harmful for your motor
in lamens terms consider the motor while in motion... everything is moving in a nice flow of genious... while parked only certain parts are moving... the parts which are supposed to be moving arent...
High rpms are a little harder on an unloaded motor than one with a load on it. Most rods break on the exhaust stroke. They are weakest with a stretching load on it like exhuast. The compression stroke offers some resistance to the piston wanting to rip the rod apart and the intake and power strokes are compressing the rod. With no load on the motor there's less exhaust pressure on the exhaust stroke. Take it for what it's worth, as I doubt anyone will actually be able to blow their motor if the low limiter was taken off. Think about manuals that let off the gas at high rpms.
WDP Director of R & D
Bottom line here,
If we are talking revving while parked, and keeping rpm's within engine design parameters, nothing should be "stretching" until you exceed those parameters.. Not something one really needs to do anyway. A rev limiter/fuel cut-off etc activating at a lower rpm while parked is just an additional safety margin. It's much easier to over rev an engine with no load than with a load.
While driving however, the manufacturer wants you to be able to use the engine within its entire operating parameters. While parked, no real reason to on a factory vehicle etc...
I have never seen any documentation stating an engine will "blow" easier with no load vs under load when operating within parameters. In every case, the root cause for the blown engine was due to exceeding the design, you guessed it, "parameters", nothing else....
I "heard" that you can drop your tranny or mess it up or something of the sort when revving it too much in neutral.
thanks
thanks
Originally Posted by KJSmitty
Bottom line here,
Originally Posted by dr_brains510
do you have a tls? if so, where did you get your injen cai cuz i can't find a cai made by injen for the 07 type s
cycdaniel
12-17-2019 10:58 AM
DerrickW
11-15-2015 05:52 PM
