Does VSA kicking in increase clutch wear?
if the clutch is fully released- foot off pedal, the traction system can only control brakes and throttle
But you are losing time if trying to get a ~jumped start~ and thats causing the vsa from wheel spin
and its hard on the cv joints and puts wear on the brakes
I was just thinking that same thing. The stress would more than likely be put on your brakes and CV joints, if anything. A few days ago in the snow, the VSA was fighting me in my driveway (until I turned it off) and since both wheels lost traction, it was cutting into the engine causing me to stall while I was slipping the clutch. Even in that case, I can't see it damaging your clutch.
if you are slipping the clutch at the same time= wear
btw: clutch replacement complete= $2800
Registered Member
Don't worry. You should be getting at the minimum at least 100,000 miles from your clutch and in reality, more like 200,000+... as long as you operate things correctly.
Jamus22
06-11-2023 10:08 AM
SidhuSaaB
05-30-2020 12:40 AM
