Does TL get steering wheel lock???
Police
I felt the steering wheel locked before I went out home... but when I came back home...
I tried to lock the steering wheel again... it didn't work anymore...(steering wheel
never locked before today.)
so i just wondering if i got a problem with the steering wheel lock or is there any special way to lock steering wheel...???
Thanx all!
Thanx all!
It locks when you turn the key off, and remove it from the ignition. Depending on the position the wheel was in when you turned the key off, you may have to move it a little or a lot to actually hear the lock "click", so try turning the steering wheel after you take the key out, and you will find you have not been cheated out of this desireable feature.
Police
i turned the steering wheel (i tried a little, also tried a lot)after i took the key out... but it didn't work...-_-bbbbbb
so do u guys think there is gonna be a problem with the lock???
If it doesn't work there is either a problem with you or the lock. Either way, taking it in to the service manager will disclose where the problem is.
Before you go, try turning the steering wheel at least 1/2 a turn. If it still doesn't lock, you probably have a problem with the steering wheel lock mechanism.
Police
rockyboy
12-06-2022 02:29 PM
braveheart
09-07-2015 08:12 AM
