does the 07 spoiler fit the 04-06 TL????
I have the 2004 black pearl TL did they make the 07 spoiler in that color? Also are there any fitment issues? I hope we can use it it looks SICk
This thread has been moved to the proper forum. Please read The "Modifications" in "Performance Parts & Modifications" announcement at the top of the Performance Parts & Modifications subforum for a full explanation.
All About Trance
I want that link too if it's for that much. What a deal in deed!
Originally Posted by dan.....k
Call him. It was not on the site. I have ordered everything directly over the phone.
i'm new at this sorry. what's tim's contact number over at hondaacura website?
Retired and Loving It
dan.....k
Please let us know how this works out. I haven't ordered the 07 type S spoiler because of the multiple holes that are required to mount it to the trunk lid. If you can post pics of the spoiler mounting before installation, it would be helpful to the rest of us considering this mod.
Has anyone actually done this MOD yet? I just talk to my dealer and he does not think that it will work, he said if you look close, the trunks are different where the deck lid monts. Secondly he mentioned the bolts the the 07 takes are going to be hard to access from the inside of the trunk......
I really want this so keep me posted if it works out
1chirotl
1chirotl
1chirotl
1chirotl
my parts dept guy said the same thing. He said there was a similar problem on the NSX. (I dont remember what years he mentioned).
I would like see one actually sitting on our car to see if looks flush or not.
The possible reason the truck part numbers are different is because the holes for the Type-S spoiler are drilled/ machined when the trunk lid is produced.
What we need to find out is if the 07 Base TL and the 06 Base TL trunk lids are the same part number. If they are the same, there is a really good chance you can mount the 07 Type-S spoiler on an 04-07 Base TL, if you can figure where to drill the holes.
I don't believe Acura made any changes to the metal parts of the exterior body of the TL for 07.
Too Fast TOO FURIOUS
Originally Posted by maxAmillion
I e-mailed Scot again and he know said the TL-S deck lip is about 1" beefier. I said he could sell me one, it's $104. The only problem is you have to drill 5 holes and 2 square holes and it doesn't come with a template.
dat, my dealer had one on display that they said is the lip spoiler for the base TL. (looked a lot like our lip spoiler to me). It had 2 bolts on it and a small strip of the double sided tape going around it. It would be possible to cut the bolts off & maybe even add more tape. I don't know how well it would hold up though.
I believe the 07 Base TL Accessory Lip Spoiler is the same as the 04-06 TL Accessory Lip Spoiler, except for the color choices of course.
It might be worth ordering a 07 Type-S spoiler for $99 and seeing if 1) the two thread bolts are spaced the same as the accessory spoiler (to uses accessory template), 2) can the three clips be removed / sanded down and 3) double stick tape be applied in similar locations as on the accessory spoiler.
acura-cl.com OG
if you were able to get rid of those bolts, i am sure a dremel would do the trick, and some automotive grade 3M tape that spoiler would mount no problems.
Personally, i wanted a secure mount, so i bought the OEM, but the decklids on ebay mount with only tape, so why won't thise work as well?
I was told by the parts guy and a tech at my dealership that the 07 TL type S spoiler is made like the TSX spoiler. We looked at the Type S on their parts computer and looked at a TSX spoiler they had is stock. The TSX spoiler has two metal studs and three plastic pins which go through the trunk and are secured with two nuts and three clips. The spoiler is hollow with several reinforcement ribs between the studs and pins. Even if you removed the studs and pins I don't think there would be enough surface area on the spoiler for the double sided tape to adhire to.
Two day ago I went down to look at the new Type S TL. I looked at the mounted spoiler very closely from all angles. The seal around the edges looks just like the TSX spoiler I looked at over a week ago. If anyone has ordered this new Type S spoiler, I'd like to see photos of the bottom and mounting studs. I would like to confirm that it is like the TSX spoiler. Once we see the bottom of new TL Type S spoiler, we can determine if it can be modified to mount without drilling all the holes.
I think the TL-S lip is too fat looking, and I like the 04-06 better. If you look at the real m3 lip, it is even more skinny than what we have. Acura should've make the lip more slim to get that aggressive look from behind just like them m3's. This is what I think. By the way, how many holes are drilled in order to install the 04-06 lips?
https://acurazine.com/forums/showpos...8&postcount=22
The 04-06 Lip Spoiler needs two holes drilled and also has 1/4 inch wide double stick tape all around the parameter of the underside of it. It also looks solid /closed which provides the surface area for the tape.
Now, someone please post pics!
Team Anthracite
okay.. i gave Tim a called.. he said the only reason why its 99 because it is NOT an accessory =) but i am outta luck... i have Anthracite Metallic........ :'( and the closes thing in 07 is Carbon Grey Pearl.....
but guys.. if you were able to install it.. give Tim a call.. =)
but couldnt we get it unpainted then have it painted to AM?
Maybe it would even be cheaper unpainted?
