Do you search for ethanol free gas stations?
Last weekend I made a trip from Madison to Chicago and on the way down (highway only) the best I could get was 35 MPG on BP premium (either 91 or 92 octane) with "up to 10% ethanol" stated on the pump.
On the way home I filled up with Shell 93 octane (I believe it's ethanol free) and for a stretch of about an hour I got 39 MPG. I know that it's only an hours worth of drive time but it's still pretty good. It was killing me driving that slow and after an hour I had to speed up.
![](http://img685.imageshack.us/img685/4394/39mpg.th.jpg)
How much of the difference do you think the gas made? Do you think it's worth filling at an ethanol free station? There are only a couple around my area and they're priced about 10-17 cents more per gallon. I'm not sure if it will give 10% better mileage with city driving.
No such thing in Arizona. Ethanol additives are mandated by law here.
BANNED
when you got 35MPG on 91/92, how long were you driving for? that 39MPG might just be because it was a steady speed/1 HR drive time.
i only use shell Vpower, i haven't even been to another gas station since i've owned my TL. i don't think that 10% really matters all that much.
Received 2,329 Likes
There are a couple here in my area, I fill up there when I can.
2007 TL Type-S NBP
Ethanol has about 70% of the energy content of gasoline. Hence, the 10% ethanol has about 97% of the energy of regular gas. Newer cars are supposedly designed to deal with the down sides of ethanol, I think it can be more corrosive to certain valve seals, but if I can find an Exxon/Mobil that's got ethanol free gas for comparable prices I try to fill up there.
Rich and Famous
Ethanol will decrease mpg, hp - and often a octane loss.
It increases corrosion and fouls up the injectors.
Its only got about half the explosive energy of gasoline
even tho the octane might be higher.
Ethanol in its purest form is like 110 octane
but its demise is H20 absortion and purity logistics.
That means water in your tank and corrosion in engine.
Overall your octane might be lower with some unknown amount of H20.
Check out Brazil's problems with 20 - 20% sugarcane ethanol.
LMAO - GM's 85% flex fuel cars !
But in Ethanol's defense ...
Its got the US Govt tax dollars backing
with strong corn mid west support.
Congress loves it !!
It has its own corporations, stocks and strong political lobby.
Its better than previous used MTBE which they found
to be toxic and cancer causing after using it a few years.
Of course ethanol may also be toxic but shhhh ...
its a money making secret.
No ethanol free gas here around chicago for atleast a decade. Either way my TL-S gets better than advertised fuel economy so it cant be all that bad. Would I rather have ethanol free gas? ofcourse, but people make it seem like its going to ruin your engine, cause horrible fuel economy, and reduce power. It does none of that.
James
James
James
James
Here is a pretty comprehensive list of the ethanol free gas stations: http://pure-gas.org/
Looks like I have a couple of options near me. I will have to give it a try
Ok slightly off topic, but how are you getting 35-39mpg? Best I've been able to do is 32 cruising at ~70.
Back on topic. BP definitely gives lower mileage compared to Shell. I also believe that the gas stations are switching back to their 'summer' blends as one day my gas mileage shot up substantially (always drops in the winter...)
I believe all MD gas stations are also required to do "up to 10% ethanol".
09-17-2015 09:01 PM
