DIY: Rattle center speaker, intake rubbing, LED dome light, custom LED DRL
Maybe someone posted the same DIY before, anyway just wanna to help anyone have the same issue like me.
1) rattle center speaker -fixed
2) intake rubbing -fixed ( better than before )
3) LED dome light
4) Custom LED DRL -in progess
1)
![](http://i131.photobucket.com/albums/p309/Jesska_Xi/DIY/center%20speaker/speakerrepl1of3pg22-421.jpg)
Took me 10 mintues to take it off. ( just don't scare you will scatch anything or what, use a "-" screw driver to pull up one side first then another side. ) I pull up the right side first, then down -> up -> left.
![](http://i131.photobucket.com/albums/p309/Jesska_Xi/DIY/center%20speaker/IMAG0155.jpg)
I remember some AZ members want to know our center speaker is 2 ohm or 4 ohm. Here is the picture.
![](http://i131.photobucket.com/albums/p309/Jesska_Xi/DIY/center%20speaker/IMAG0149.jpg)
Here is what I did to fix the rattle. Its pretty thick almost half inch thick. Got it from dealer. ( They don't fix problems on sunday ) I was like WTF.....I went there for 45 miles....
![](http://i131.photobucket.com/albums/p309/Jesska_Xi/DIY/center%20speaker/IMAG0157.jpg)
I thought I made some scatches....
![](http://i131.photobucket.com/albums/p309/Jesska_Xi/DIY/center%20speaker/IMAG0158.jpg)
After clean up, it looks fine!! And it sits just like before.
![](http://i131.photobucket.com/albums/p309/Jesska_Xi/DIY/center%20speaker/IMAG0160.jpg)
2)
Here is some photos for what I did to fix the AEM V2 intake rubbing issue, after that I still hear a little squeak noise in high RPM but a lot better than before.
![](http://i131.photobucket.com/albums/p309/Jesska_Xi/DIY/intake/IMG_0311.jpg)
![](http://i131.photobucket.com/albums/p309/Jesska_Xi/DIY/intake/IMG_0312.jpg)
![](http://i131.photobucket.com/albums/p309/Jesska_Xi/DIY/intake/IMG_0313.jpg)
![](http://i131.photobucket.com/albums/p309/Jesska_Xi/DIY/intake/IMG_0318.jpg)
3) It is a easy DIY, but I am going to show a easier way to take off the dome light cover and 100% no scatches!
Grab a useless card and do the same thing like the picture below, either push in harder or pull out harder then the cover comes off automatically.
![](http://i131.photobucket.com/albums/p309/Jesska_Xi/DIY/dome%20light/IMAG0168.jpg)
![](http://i131.photobucket.com/albums/p309/Jesska_Xi/DIY/dome%20light/IMAG0167.jpg)
Very bright....
![](http://i131.photobucket.com/albums/p309/Jesska_Xi/DIY/dome%20light/IMAG0171.jpg)
4) (still work in progess, I will post the final result after a week...)
What I need:
-20 pcs 5W high power LED (194 size)
-20 pcs marble ( I bought 20 bottles of japanese soda with marble)
-Dremel 8200 12V
-Dremel workstation
-a plastic board from lows
The marble is doing the projector job, focus the light to the front.
![](http://i131.photobucket.com/albums/p309/Jesska_Xi/DIY/custom%20led%20DRL/IMG_0456.jpg)
![](http://i131.photobucket.com/albums/p309/Jesska_Xi/DIY/custom%20led%20DRL/IMG_0463.jpg)
Here is a demo..without the marble. The LED will look X2 bigger after adding the marble...
![](http://i131.photobucket.com/albums/p309/Jesska_Xi/DIY/custom%20led%20DRL/IMG_0458.jpg)
![](http://i131.photobucket.com/albums/p309/Jesska_Xi/DIY/custom%20led%20DRL/IMG_0460.jpg)
![](http://i131.photobucket.com/albums/p309/Jesska_Xi/DIY/custom%20led%20DRL/IMAG0173.jpg)
![](http://i131.photobucket.com/albums/p309/Jesska_Xi/DIY/custom%20led%20DRL/IMAG0172.jpg)
![](http://i131.photobucket.com/albums/p309/Jesska_Xi/DIY/custom%20led%20DRL/IMAG0174.jpg)
More photos will come up in one week.
3) LED dome light
1)
2)
Very bright....
What I need:
-Dremel 8200 12V
-Dremel workstation
david_vang (11-17-2012)
So I search in AZ and I discover that I can connect the wire to the fuse box with an "ADD-a-FUSE", I look at the car manual and I found the interior fuse box No.32 fuse can do what I wanted but I want to know if anyone knew there is a fuse under hood can do the same thing for me?
I want the light on when I start the engine and off when I turn off the engine. But not light up when the key is in the first position.
Anyones help? I want to install that ASAP and post up photos....
sorry for bump. just excited to share that the speaker fix worked great for me. no more center speaker rattle. now i just have some minor rattles in the back.. seems like it could be the sub. and sometimes there's rattle from the driver side door.
It seems that all the images for your repairs have been deleted somehow! I was wondering specifically how to repair the front center speaker rattle. If you could repost the picture for this and what you used, I would be grateful! Thanks!!!
Ok I admit the posting is old, but I'm sure people are going to continue having these issues, so I'm just wondering if anyone else has had any luck fixing that center speaker rattle, because its driving me nuts! I've already tried putting some thin foam weatherstripping around the edges of where the speaker lid sits, but it hasn't helped at all. I thought it would since even the slightest pressure from my hand on top of the cover while driving seems to make the rattle go away. Just wondering if a bunched up rag or similar actually underneath the speaker to push up on it from underneath might help?
Engineer in Training
rockyboy
01-25-2016 06:00 PM
Oakes
Wash & Wax
10-12-2015 11:17 AM
