DIY Bumper Plugs
Registered Member
DIY Bumper Plugs
Does your state not require you to run a front plate?
Do you choose not to run a front license plate anyway?
Are you tired of the look of missing bumper plugs?
Are you disgusted that it costs over $70 to get OEM bumper plugs from the stealership?
Well if you answered yes to any of these questions, then I have a very simple and cheap solution for you!! Make your own at a fraction of the cost!
Here is everything you will need:
Bumper Plugs, these can be picked up at any local auto store, Advanced Auto, Auto Zone, etc. They were about $4 for small pack of them. I found this size fit the holes perfectly.
Then get some OEM paint. I actually found this on Amazon for $6.50. It has an applicator brush and it is also a pen to fill scratches.
I bought adhesion promoter since the plugs are plastic. You may or may not need it, but I figured it would be better to use it so I bought a can. You'll also want to pick up some clear coat if you don't already have a can laying around the house from a prior project. Both were about $6 a can and I got them at Auto Zone.
Once you have everything you need, now you can paint the plugs. I did about 3 coats of adhesion promoter and let it dry. Then using the OEM paint I did 4 even coats waiting 30 minutes in between coats to make sure it was totally dry. After that I did 4 coats of clear, again waiting about 30 minutes in between coats.
I waited 24 hours before installing them on the car to make sure the plugs were completely dry since you will be pushing them somewhat hard into the bumper. You will need to use a drill bit to create a hole for the back of the plug to go into. You can see the holes I drilled here.
The finished product:
The following 4 users liked this post by The Machine:
awesome job, welcome back
The Machine (09-19-2015)
Tycoon
Wow that looks great! I was looking for bumper plugs a few weeks back and I went to my local Radley Acura dealership and they were charging me $60 a pop for each! I was like.. no thanks.. luckily I had a very nice board member that hook me up with some. This is a wonderful idea here! Props!
The following 2 users liked this post by robowarrio:
The Machine (09-19-2015),
Typesdavid44 (11-07-2019)
TL-S
Tycoon
The Machine (09-20-2015)
this is great because I actually was about to order some since im tired of waiting for them in the black market. just throwing it out there though, the paint is actually cheaper from the dealership, unless you have WDP then idk because its like $15 dealer, all other colors $5.56 dealer, $6.65 amazon.
The following 2 users liked this post by smsTL:
scionxb3003 (09-20-2015),
Registered Member
Thanks for the love guys. I'm glad everyone is enjoying it and you now have a nice alternative to spending a crazy amount for OEM plugs.
Scionxb3003, if you think about it, if you had to use the OEM license plate bracket up front, the screws you would have to use basically make a hole anyway. This part is kind of hard to describe, but if you stick your hand behind the bumper where the screw would go through, you will feel a hard plastic piece. That piece is basically like an attached nut. So when the license plate screw goes through, it threads this piece and it holds the screw in place.
No matter what, you will have to make some type of hole for the plug to go into because it needs to be able to grip onto something. The OEM plugs are designed differently to where you don't have to make a hole, they just snap into place like a center cap on a rim would. If you look closely at the bumper you will see 4 little cut outs that the OEM bumper plugs connects into, so that's why you don't have to make a hole if you use OEM.
The following 2 users liked this post by The Machine:
EvilVirus (09-21-2015),
I just went and looked at what you are talking about. Im just going to do what you did and if need be ill buy larger screws to put the plate back on. thank you very much for this. it would be done today if acura was open for me to buy the paint.
Ingenuity! well done Chip!
Luckily for me too, a member hooked it up with some bumper (read:butt) plugs!
The Machine (09-21-2015)
<p>Damn man nice job. I can't believe this is the first time I've seen this considering their ridiculous price. </p>
The Machine (09-22-2015)
EvilVirus (09-27-2015)
Received 6,470 Likes
Well done, buddy!
The Machine (03-12-2016)
Tycoon
EvilVirus (10-04-2015)
ITSJESTER
17
12-06-2018 02:29 AM
Joe Avesyan
09-29-2015 03:57 PM
