debadged 1 wk old car, still see imprint .. help
so clean
hey guys, i just recently purchased an 06 TL in NBP. after i debadged the "ACURA" emblem, i could still slightly see the imprint of where the "ACURA" used to be. the "TL" emblem came off pretty clean. any ideas on how i could fix/cover it up? will it go away w/time? thanks guys!
I had the same problem. What I did was first use goo gone to make sure all the glue was gone. Then i put on two coats of Meguiars Scratch X and then three coats of Meguiars NXT paste wax.
so clean
thanks for all ur help guys, the alcohol did help a bit and i just added 3 layers of wax ... can still kinda see it, but i'll survive
might need to pick up some scratch X tho
WDP Is Faster
My bro has a NBP RSX and we debadged it but it still had that imprint on there. What i did was use goo gone, rubbing alcohol, quick wax on it but it still was left on there. Just wait it out. All I do that car now is just regular washes whenever he comes back and now, I can't see it. Patience man.
Your dealer should have adhesive remover...they use it for the final detail before you pick up your car to get off the adhesive from the plastic that covers the car during shipping. Take a small bottle in to your dealer and ask for some. I am pretty sure it is just goo gone, but if your dealer uses it then it has to be ok.
it's 4:20
Originally Posted by pimpin-tl
Do NOT use Paint Thinner. This will damage the clear coat.
Just get some Scatch X or some type of light rubbing compound and polish to take it out.
CTS-V Import Slayer
This will fade over a few days to a week to invisible once that area gets exposed to the same elements and oxygen in the air. It has been under "wraps" more or less to now. Usually some carnuba wax will take it away too...but either way...it will go away soon once exposed to the elements. If you did NOTHING...it would still fade in about a week.
If its the adhesive thats still there a soft cloth and WD-40 will remove it .. if its a ghost then a soft cloth and ScratchX.. Don't jump into the rubbing compound too fast .. you get the wrong one and you will have marring to try and fix next.
Also some of the adhesive removers and such have Xylene in them and its not very clear coat friendly and can cause clear failure down the road.
Uses turn signals in my
try goo-gone and bug & tar remover, worked really well on removing the 'shadow' on my friends 99 m-a-x-i-m-a lettering. We also used wd-40 and cleaner wax, but it seemed like the other stuff did the main trick. Hit it up with some more wax after your done and you should be all good.
Originally Posted by Darknesss_TL
yea man, why wouldn't it be?
give it a week or two.
it will fade.
I debadged my car which is 15 months old. Heated badges with hair dryer, used dental floss, then Turtle Wax Bug & Tar Remover, and carnauba wax. Didn't even need to wax because everything was clean without leftover imprints, but did it just for the hell of it. Looks great
what i did was used a heat gun and then even after going that route, i still had some residue. i wetted the area and rubbed it with latex gloves on. that got the bulk of it off. and i agree with the scratch X, that stuff will clear it out perfectly! good luck bro
Styl1n
I just did mine last night, you have to compound it, then polish it and finish with Wax....the imprint was there and after I finished buffing it.....it was crystal clear....on an 02TLS
Legend2TL
Motorsports News
01-31-2016 09:27 AM
