Curious question about power steering fluid
So here's the story...
The dealer had my car about 2 - 3 weeks ago to fix the idler pulley TSB (07 base) which entails removing the serpentine belt.
About a week ago, I noticed a weird whine/buzzing whenever i get to 2000 rpm. I checked all the heat shields including the intermediate shaft shield and those all appear fine. While i was under the car, I noticed some oil on the passenger side towards the front bumper. So I remove some of the shroud in the engine bay and found the power steering reservoir sitting next to my serpentine belt. It appears the tech forgot to put it back into its proper place, and it had been left loose, with the belt rubbing on it.
The reservoir was just above the min line and fluid was all over the belt, pulleys, etc. There is a gash on the reservoir where the belt was rubbing on it.
I put the reservoir back in its holder and took the car for a drive, but the noise is still there.
Could power steering fluid on the belt and pulleys have caused any damage that is making the noise? For instance, did it damage any bearings etc?
Taking it back to the dealer tomorrow to show them, but would really like to know what you guys think. By the way, my dealer has really been good and I realize that mistakes happen, so I don't want to bash the dealer.
Thanks alot.
Thanks alot.
AZ Community Team
Received 7,771 Likes
They should probably replace the reseviour as well since it's damaged. It's a pretty low-cost item, so it shouldn't be a big deal.
Thanks alot.
Thanks alot.
http://www.gatesprograms.com/beltwear/inspection
You should also check to see if the belt needs replacement anyway.
mike from annapolis
05-07-2017 08:21 PM
asahrts
09-04-2015 05:55 PM
