Crank shaft pulley tool
Old 04-01-2017, 01:29 AM
BANNED
Silver 3.5's Avatar
Was wondering if anyone has a 50 mm crank shaft pulley removal / install tool. I'm more interested in buying an actual Honda tool, not a tool that might bend or break. Any info as to where i could purchase one online or should i just go to the dealer? Thanks.
Old 04-01-2017, 02:01 AM
Received 8,743 Likes on 6,745 Posts
Have you had a problem with the powerbuilt one ? Powerbuilt 648796 Honda Cranks Pulley Removal Tool
Amazon Amazon
Old 04-01-2017, 02:29 AM
BANNED
Silver 3.5's Avatar
Have you had a problem with the powerbuilt one ? Powerbuilt 648796 Honda Cranks Pulley Removal Tool https://www.amazon.com/dp/B0000TMLWQ..._Fa13yb4VEARNT
I haven't purchased one yet. Have you used the powerbuilt tool before? Is it made for a half inch breaker bar?
Old 04-09-2017, 12:04 AM
BANNED
Silver 3.5's Avatar
I purchased the tool from home depot, Capri Tools. basically same quality as described by powerbuilt.
It costed me 20 bucks and it took me 2 tries with a 2'.8" cheater bar to break the bolt loose. Worth it
Old 04-09-2017, 07:39 AM
blueracer17's Avatar
Your local major autoparts retailer will likely have this tool available to rent for free. Why spend the $$ if you don't have to? Just my opinion.
Old 04-09-2017, 08:19 AM
thisaznboi88's Avatar
Get this his tool and hit the crank bolt with item an impact gun. Comes off so easy
or do the starter blimp. That's free
Old 04-13-2017, 02:08 AM
BANNED
Silver 3.5's Avatar
Still Have to hold the crank pulley...
Old 04-13-2017, 05:39 AM
Turbonut's Avatar
Not if you have a high torque impact.
Here's an IR-780 ft-lbs of maximum forward/reverse torque & 1100 ft-lb of nut-busting torque, but @ $500.
Old 04-13-2017, 07:23 AM
Don't have to hold the crank. I have a UR pulley so nothing to hold. Just get an Impact gun. Lets see if my 350fl/lb electric impact with this socket can get it loose
Old 04-13-2017, 08:09 AM
nfnsquared's Avatar
Received 1,795 Likes on 1,348 Posts
^^^^^^ With the UR pulley, how do you torque it to 180 when you put the bolt back on?
Old 04-13-2017, 08:53 AM
Good questions.. I Just say Fk it and hit it with the impact. lol Probably the worst thing you can do,
Old 04-13-2017, 01:35 PM
Just used that socket i posted up today. Took it off the car in 2-3 sec. Made that crank pulley bolt look like a lug nut. My corded impact gun only rated for 350ft/lb of tq. So you get the idea. Probably a HF one with this socket would save you a bunch of time and cussing. From beginning to end it took about 45 mins. Most of the time was spent jacking up the car take positioning the jacks
Old 04-13-2017, 01:44 PM
BANNED
Silver 3.5's Avatar
That's a pretty cool socket, but I wouldn't feel comfortable torquing the bolt back down with an impact gun. It didn't take me no more than a minute to get the bolt off with the correct tools. And a second hand to torque it back down.
Old 04-13-2017, 02:00 PM
definitely feel you on that, but those lightweight crank pulley don't have a place to hold it.
Old 04-13-2017, 04:17 PM
nfnsquared's Avatar
So are you MT or AT? It doesn't turn the engine over when tightening with the 350 ft-lb impact wrench?
Old 04-13-2017, 04:57 PM
6MT and not it didn't turn the engine when I hit it in the impact to tighten it. I use a regular impact socket, not that 2lb slug. Got it tight and then made a 1/6 of turn on the bolt. That should be enough to keep it from flying off. Already took it for a 20 mins drive no problems
took off my stock diameter UR one and put back the stock oem crank because selling the car. So semi-part out.
Old 04-14-2017, 03:08 AM
BANNED
Silver 3.5's Avatar
can you post a pick of your crankshaft pulley. Or list the manufacturer. I would like to see what it looks like, thanks.
Old 04-14-2017, 07:48 AM
Stock diameter
Old 04-15-2017, 01:26 AM
BANNED
Silver 3.5's Avatar
who makes that pulley? and did you feel anything different by putting that one on?
Old 04-15-2017, 07:38 AM
Search there a thread about this on here with dyno graphs. But yes the car Rev and accelerate just a little bit faster. I put the stock one on since my car is turbo and selling it in a few days
Old 04-15-2017, 03:48 PM
Turbonut's Avatar
Just like to add, if everyone believes the dealerships, or even independents, use a torque wrench when tightening the bolts down, I have a bridge for sale.
In fact, some of the bolts on the Acura are well above the factory torque specs. Guess the robot had an off day.
thisaznboi88 (04-15-2017)
Old 04-17-2017, 11:00 AM
Jrad96TL's Avatar
Hey guys I'm balling on a budget at the moment would u think that this impact wrench plus the lisle socket could remove the bolt ? http://m.sears.com/capri-tools-capri...Q&gclsrc=aw.ds
Old 04-17-2017, 11:40 AM
Maybe or HF special
Electric Impact Wrench - 1/2"
this is the one I personally use
https://www.lowes.com/pd/Kobalt-8-Am...Wrench/3307992
Old 04-17-2017, 01:14 PM
Jrad96TL's Avatar
Thanks I'll give it shot btw that eBay link doesn't work
Old 04-17-2017, 01:37 PM
sorry it was a lowes not an ebay linkKobalt 8-Amp 1/2-in Corded Impact Wrench
Old 04-17-2017, 03:17 PM
t-rd's Avatar
There was a deal on a Milwaukee M18 for $249 just a month ago from Dewalt Tools, Greenlee Tools, Ridgid Tools, Milwaukee Tools, Proto Tools | Toolup.com with no tax, this is what I bought. Same nut busting torque rating as the competing Ingersoll Rand and Dewalt.
Old 04-17-2017, 06:27 PM
nfnsquared's Avatar
It sure might, but really don't have any way of knowing for sure.
Old 04-17-2017, 06:45 PM
have a can of PB blaster ready. You live in Florida so rust should not be an issue compared to people above the salt belt.
MrVtech
12-14-2016 03:37 PM
MrVtech
11-24-2016 02:11 PM
ExcelerateRep
New England
10-04-2016 04:01 PM
Quick Reply: Crank shaft pulley tool
