Converting foglights to Xenon on 2007 TL
Has anyone coverted or know how to convert the foglights on a 2007 TL to Xenon? I searched the sight and found nothing.
OMGWTF4THGENTL
Originally Posted by erigan
you need to buy a new HID kit and get xenon bulbs.
the kit is 9006 size.
B A N N E D
I think most decent HID kit actually comes with a wiring harness that take power directly from the battery. Some of the cheaper ones might tell you to just use a bigger a fuse. However I think the fuse are set at a certain amount for a reason. Most likely the stock wiring would not be able to take the sudden big surge of power when the HID ignites.
You'll need to purchase a separate xenon kit with harness & ballast (as mentioned) with a relay switch to the stock wiring to the fogs -- so that when you flip the fogs on via the stalk on the left of the steering column, you'll allow the xenon ballast (a device that draws power from your battery, has its own fuse) to start drawing power from the battery. It's not a very technically challenging install, just need to be able to find a decent place to mount two ballasts (one for each xenon light .. or one ballast for both lights... depending on the xenon kit you buy).
I think xenon fogs in the integrated '04/5/6 headlamp is OVERKILL...
This thread has been moved to the proper forum.
Please read The "Modifications" in "Performance Parts & Modifications" announcement at the top of the Performance Parts & Modifications subforum for a full explanation.
quanaman
01-09-2023 07:33 PM
MetalGearTypeS
08-29-2016 08:28 PM
