clutch replacement parts
Hi Everyone! I was wondering if any of you have or know of all the parts needed to replace the factory clutch. I'm going to need to replace my clutch on my 2005 Acura TL and was thinking about what parts I needed ( was thinking about buying them and then getting them put on and saving some money) Also, if it's only a couple of bucks more maybe getting an performance one instead. Thanks for any and all assistance in this matter!
eduble2
eduble2
when i did mine i got the whole clutch kit from acura....and then i went and got all the bolts that hold it in place spring n fork for the throw out bearing including all the bearings.....i wasnt taking any risks. it all cost like 700 including the flywheel which in my case needed replacement.
"Advance"
Clutch : http://www.acuraoemparts.com/delray/...All&vinsrch=no
Clutch MASTER: http://www.acuraoemparts.com/delray/...All&vinsrch=no
Not sure if you need something else, but that seems enough!!
Thanks! For the info! But I still uncertain on what to do. If my clutch is slipping, is there a way to know if I just need to replace the clutch and/or the fly wheel instead of the clutch master (which I don't know what it is). I heard that if I replace my clutch , I should replace my fly wheel as well. Is this true?
Also, would it be worth my while to replace the clutch with an performance one instead, since it has to be replaced anyway??
I'd love to hear your thoughts and others as well!
SUPRMN84
09-02-2015 11:50 PM
