Climate Control System
I purchased my 2004 TL in Feb 2004. I have had no problems with it until today. Today morning when I was driving to work, I wanted to change the Temp. So I hit the Up arrow....It would not work, so i checked the other buttons and none would work except the Last two buttons on the lower right had side the defroster for back and front. Nothing else would work.
So I started the car again, did that couple of times nothing happened.
Then I started driving towards work and after 10 mins or so, I tried it again and started working normally.
Finally reached work parking lot and changed the gear to park and turned off the CD player, and now I am not able to turin of the AC. Again the same situation, finally after pressing multiple buttons, I was able to turn off the AC.
So I tried to turn it ON again, and again nothing would work.
Has any one experienced this with there New TL's or even old.
Or does it seem to be a faulty climate control unit.
thanks
Div
thanks
Div
You have said or done something that pissed off your Navi, and now s/he is getting you back. Do not cuss at the Navi, do not push real hard on the screen, and no matter what, do not, I repeat do not, turn the Navi off. Give her/him a few days to cool off, say you're sorry several times, and everything should be back to normal after that.
mada51589
05-03-2022 08:54 PM
