Changing outside door handle
![Question](https://acurazine.com/forums/images/icons/icon5.gif)
How difficult is it to change the outside door handle? I scraped the left (driver) side front door handle and lock cover against my garage. I had replaced the original lock cover with the same used for the left rear door to conceal the keyhole.
Will I have to remove inner door panel for anything or can it all be done from the outside?
Also, are these the correct parts:
- Left-side door handle
- Left-side rear lock cover (in place of the keyhole access cover)
yes, that is the part and the cap. The door panel needs to come off and you unhook a pin and latch to get the handle part out along with a few screws. The paint color might not match 100% as your paint has 14 yrs of wear and tear vs new paint.
Even if the paint doesn't match perfectly, it'll look better than it does now.
Is there page from a shop manual showing the procedure or is it pretty self explanatory if I hold the door handle open?
There are links here on the forums for the service manual. Highly recommended, especially for finding out where any hidden/tricky fasteners are located.
Also worth noting on these cars door panels, there is one fastener that tends to strip/rotate. To remedy this, I just grabbed the fastener with pliers (once removing the rubber cap) and pulled. To reinstall I just pushed it back in place.
door handle open..
no you need to tear open the inside door panel to get access to the handle from the inside.
![Scratch](https://acurazine.com/forums/images/smilies/scratch.gif)
I'm also an expert at asking stupid questions. My wife can vouch for that.
RHPotter
06-26-2008 04:53 PM
