Caution light on 2005 Acura TL
I Just test drove a 2005 Acura TL. It had 59,000 miles, an automatic transmission, and drove smoothly. There was thing that irked me however. There was a yellow caution light lit up on the dash. I asked the dealer about it and he said it only came on because the car hadn't been moved for a long period of time. He also assured me his mechanic would take care of the issue and the light would be gone by the time I bought it. I've only been driving for about two years and barely know anything about cars but a caution light sounds like bad news. What do you guys think is the reason that the light was on and what should I do?
Originally Posted by Fulani has a TL
You 23 and only been driving for 2 years??
Word of the wise, DONT BUY THE CAR!!!!
All they will do is reset the CEL.
Originally Posted by Crazyace718
I live in New York public transportation is just as fast if not faster most of the time.
Makes sense...
Hard to tell what the actual problem is unless you run an OBDII on it.
Registered but harmless
Received 1,107 Likes
Originally Posted by fluxcapacitor3000
what wud be the problem if that light came on neways?
However, the "Check Engine Light" (CEL) may indicate that there's a problem diagnosis code that can be read by an OBDII scanner. Sometimes the CEL will come on due to innocuous issues (failure to tighten the gas cap) as well as major ones (misfires in all cylinders, emissions control out of whack)-- but someone has to pull and read the code.
General rule: if a used car has a CEL on when you're looking to buy,
![Run](https://acurazine.com/forums/images/smilies/run.gif)
Which light was it, the check engine light or a yellow triangle with an ! in the middle of it?
That light just indicates traction control is off. It is very easy to brush against the VSA off button, to the right of the steering column.
The default is traction control on. So that is why, when you restart the car, the light goes away.
In the case of this car, if you have restarted the car and the light is still on, then there may be a problem with VSA.
If it fails to go away upon restart, don't get the car.
![Dunno](https://acurazine.com/forums/images/smilies/dunno.gif)
Legend2TL
11-20-2015 07:31 PM
handsom-hustla
11-13-2015 05:04 PM
nuldabz
09-03-2015 05:49 PM
