Car won't beep when press lock twice on Transponder.
Ok fellas I have a 04 Gen3 and have noticed that ever since I bought the car the car does not beep when you press the transponder twice to lock. I read on the forums and saw that a few people had the same problem. So what I did was check all the door locks and trunk lock to see if they would activate when I opened them on the dashboard and they door. But when I open the hood it doesn't do anything on the dash. So what I did was lock the car and armed the alarm with me in it and tried popping the hood and the alarm didn't not go off. So I'm thinking it has something to do with the hood not sending a signal to the alarm to tell it that its locked. Any ideas what part I need to replace to fix it??
i think your issue is the keyless lock acknowledgement setting is set to "off"... you didn't specify year of your TL.
http://techinfo.honda.com/rjanisis/p...707O00081A.pdf
Anthracite'04 (12-21-2014)
BANNED
^-- what are you talking about, it totally wasn't there before.
My info is no good then, but probably a similar setting on the '04.
my bad. lol
my bad. lol
BANNED
I have a 2004 and even though the setting on the MID is turned on, my car still doesn't beep.
Yep, my alarm works fine, but the car doesn't have that high-pitched beep when I lock it via the remote.
RAR
does the beep work with the passenger 2 key?
When I reprogrammed all my keys somehow my master key wasnt set properly so the passenger 2 key beeps but not the primary.
My guess is I would need to reprogram all my keys to fix
Stay Out Of the Left Lane
Received 1,237 Likes
Do you get the red flashing LED telling you that system is in fact armed?
Yes next to the drivers lock it blinks red and on the radio it blinks as well if I open any of the doors from the inside the alarms goes off and if I pop the hood the alarms off too.. I'm starting to think its the mechanism that makes the beeping noise thats bad.
I'm thinking you are right.
The alarm is actually arming as evidenced by the flashing LED.
You can set off the alarm as noted above.
The only thing seemingly missing the the confirmation beep.
http://www.acura-tsx.com/forums/showthread.php?t=547818
See #15.
I actually haven't looked for it myself.
See #15.
NBP
Hey I need help too. 2003 A-spec I need to locate where the beep sound is comming from. I arm the car and I can barely hear the beep sound need to know what/where it is so I can change it,
keyless lock
Originally Posted by JonathanTL
I have a 04 aacura tl, I have the same problem everytime that I press lock twice does not beep, and I already check the settings and the BEEP is ON but doesn't beep when I lock
Oh Sickest TL (06-20-2016)
I had my TL for 7 years and it never beeped. Door lock actuators were fine.
Mine has always beeped
It's been awhile since I looked this up and know I have posted it previously but believe the alarm protection circuit consists of the following:
4x doors
Trunk
Engine Hood
Radio
Ingnition.
if te circuit isn't closed (complete) it won't beep. You can also tell by the flashing red LED on the driver's door. I believe if that if flashing the alarm circuit is closed and armed. If you still aren't hearing the beep., it could be the beep mechanism itself.
4x doors
Trunk
Engine Hood
Radio
Ingnition.
tman570
06-11-2019 07:56 AM
