Can I retrofit 2010 MDX keys to my 2006 TL keys?
Old 04-06-2015, 11:36 PM
nvasion's Avatar
got an extra set of 2010 mdx keys and I want to see if I can make it work with my 2006 acura tl..
the mdx key is already cut and programmed to the mdx.
I was wondering is there a way I can transfer my current key and chip into the mdx to make it work?
any threads about this?
thanks for the help in advance!
Old 04-07-2015, 12:44 AM
truonghthe's Avatar
Received 1,692 Likes on 1,307 Posts
Ah simple answer is no. You will have to buy a blank key and cut then program for the TL.
Old 04-07-2015, 08:05 AM
guitarplayer16's Avatar
Received 2,316 Likes on 1,690 Posts
Yes, you can retrofit it as long as the FCC ID of the remotes are the same.
https://acurazine.com/forums/first-g...photos-671520/
You wouldn't be able to just buy a blank and have it cut, since 07/08 is laser cut and 04-06 is milled.
nvasion (04-07-2015)
Old 04-07-2015, 12:55 PM
nvasion's Avatar
anychance you have the FCC ID for the tl?
my keys are so old they got rubbed off and my second fob is at home.
Old 04-07-2015, 01:09 PM
Registered Bunny
polobunny's Avatar
Received 1,073 Likes on 892 Posts
OUCG8D-439H-A and E48G8D-444H-A will work, 2500A-HLK1T will not work. Others I don't know!
Old 04-07-2015, 02:02 PM
nvasion's Avatar
Crap mdx is n5f0602a1a
johnalfa
11-05-2015 06:44 PM
IIDXholic
3G RLX (2013+)
23
10-19-2015 09:40 PM
LeVeL
10-18-2015 04:19 PM
chiu0nthls
3G MDX (2014-2020)
09-28-2015 03:46 AM
kixo
09-25-2015 03:07 PM
Quick Reply: Can I retrofit 2010 MDX keys to my 2006 TL keys?
